pwm and 4 push button
so hi im doing this project and I meet a little chalenge . this project has for purpose to :
-be able to make two push button one to increase the intensity of the led and the other to decrease the light intensity
-be able with a third push button turn on both of the light when i press one time and when press a second time he only turn off one light
so here what i have done so far the 2 push button to increase and decrease work well but the third button doesn't work when i push it doesn't anything
const int led1 =3;
const int led2 = 5;
const int Cdeled1=8;
const int Cdeled2=9;
const int CdePwmPlus=6;
const int CdePwmMoins=9;
const int ledcercle1=2;
// definir les variables
int Val1PWM=0;
int Val2PWM=0;
int Val3PWM=0;
int ValCdeled1=0;
int ValCdeled2=0;
int ValPwmPlus=0;
int ValPwmMoins=0;
int selectioneur=0;
int variable=0;
  // initialise
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(Cdeled1, INPUT);
  pinMode(Cdeled2, INPUT);
  pinMode(CdePwmPlus, INPUT);
  pinMode(CdePwmMoins, INPUT);
  pinMode(ledcercle1, INPUT);
  analogWrite(led1, 0);
  analogWrite(led2, 0);
  Val1PWM=0;
  Val2PWM=0;
  Val3PWM=25;
  ValCdeled1=0;
  ValCdeled2=0;
    // lire etat bouton ValPwmPLus
 ValPwmPlus= digitalRead( CdePwmPlus);
  if (ValPwmPlus==1)
   Val1PWM=Val1PWM+10;
 ValPwmMoins= digitalRead( CdePwmMoins);
  if (ValPwmMoins==1)
  Val1PWM=Val1PWM-10;
   if (Val1PWM>250)
   Val1PWM=Val1PWM-10;
   if (Val1PWM<0)
   Val1PWM=Val1PWM+10;
  // lire etat bouton CdeLed1
  ValCdeled1= digitalRead(Cdeled1);
  if (ValCdeled1==1)
  analogWrite(led1, Val1PWM);   // allume cercle1 avec une certaine quantité de lumiere
  analogWrite(led2, Val1PWM);
 ValCdeled2= digitalRead(Cdeled2);
  if (ValCdeled2==1)
  analogWrite(led2, Val1PWM);         // Eteint cercle exterieur
  delay(100);
 selectioneur=digitalRead (ledcercle1);
    if (selectioneur==1)
    if (variable==0)
  variable=1;
 Serial.print(variable);
  analogWrite(led2, Val2PWM);
  variable=0;
moonsunn:
In what way does it not work?
It makes people happy when you use code tags and format in the IDE with ctrl-T.
