Hello,
I was hacking around with sd/mmc and audio pwm on arduino. I am trying to get the arduino to playback raw sound data from mmc on PWM pin 3. However I got lost trying to get PWM audio example from playground to work on Pin 3 instead of Pin 11. All I can get from the speaker is a high pitch sound which I think might be the 8000hz carrier.
Could one of you uberhackers check what might be going wrong?
By the way comments are from the pwm example on the playground so they may not be accurate.
* speaker_pcm
* Plays 8-bit PCM audio on pin 11 using pulse-width modulation (PWM).
* For Arduino with Atmega168 at 16 MHz.
* Uses two timers. The first changes the sample value 8000 times a second.
* The second holds pin 11 high for 0-255 ticks out of a 256-tick cycle,
* depending on sample value. The second timer repeats 62500 times per second
* (16000000 / 256), much faster than the playback rate (8000 Hz), so
* it almost sounds halfway decent, just really quiet on a PC speaker.
* Takes over Timer 1 (16-bit) for the 8000 Hz timer. This breaks PWM
* (analogWrite()) for Arduino pins 9 and 10. Takes Timer 2 (8-bit)
* for the pulse width modulation, breaking PWM for pins 11 & 3.
* Michael Smith <michael@hurts.ca>
#include <stdint.h>
#include <avr/interrupt.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <sd-reader_config.h>
#include <sd_raw.h>
#include <sd_raw_config.h>
#define SAMPLE_RATE 8000
* The audio data needs to be unsigned, 8-bit, 8000 Hz, and small enough
* to fit in flash. 10000-13000 samples is about the limit.
* sounddata.h should look like this:
* const int sounddata_length=10000;
* const unsigned char sounddata_data[] PROGMEM = { ..... };
* Then add "PROGMEM" in the right place. I hacked it up to dump the samples
* as unsigned rather than signed, but it shouldn't matter.
* mplayer -ao pcm macstartup.mp3
* sox audiodump.wav -v 1.32 -c 1 -r 8000 -u -1 macstartup-8000.wav
* sox macstartup-8000.wav macstartup-cut.wav trim 0 10000s
* wav2c macstartup-cut.wav sounddata.h sounddata
int ledPin = 13;
int speakerPin = 3;
volatile uint32_t sample;
uint32_t sounddata_length = 29376;
// This is called at 8000 Hz to load the next sample.
ISR(TIMER1_COMPA_vect) {
if (sample >= sounddata_length) {
sample = 0;
else {
byte a;
sd_raw_read(sample,&a,1);
OCR2A = a;
++sample;
void startPlayback()
pinMode(speakerPin, OUTPUT);
// Set up Timer 2 to do pulse width modulation on the speaker
// pin.
// Use internal clock (datasheet p.160)
ASSR &= ~(_BV(EXCLK) | _BV(AS2));
// Set fast PWM mode (p.157)
TCCR2A |= _BV(WGM21) | _BV(WGM20);
TCCR2B &= ~_BV(WGM22);
// Do non-inverting PWM on pin OC2A (p.155)
// On the Arduino this is pin 11.
TCCR2A = (TCCR2A | _BV(COM2B1)) & ~_BV(COM2B0);
TCCR2A &= ~(_BV(COM2A1) | _BV(COM2A0));
// No prescaler (p.158)
TCCR2B = (TCCR2B & ~(_BV(CS12) | _BV(CS11))) | _BV(CS10);
// Set initial pulse width to the first sample.
byte a;
sd_raw_read(0,&a,1);
OCR2A = a;
// Set up Timer 1 to send a sample every interrupt.
cli();
// Set CTC mode (Clear Timer on Compare Match) (p.133)
// Have to set OCR1A *after*, otherwise it gets reset to 0!
TCCR1B = (TCCR1B & ~_BV(WGM13)) | _BV(WGM12);
TCCR1A = TCCR1A & ~(_BV(WGM11) | _BV(WGM10));
// No prescaler (p.134)
TCCR1B = (TCCR1B & ~(_BV(CS12) | _BV(CS11))) | _BV(CS10);
// Set the compare register (OCR1A).
// OCR1A is a 16-bit register, so we have to do this with
// interrupts disabled to be safe.
OCR1B = F_CPU / SAMPLE_RATE; // 16e6 / 8000 = 2000
// Enable interrupt when TCNT1 == OCR1A (p.136)
TIMSK1 |= _BV(OCIE1B);
sample = 0;
sei();
void stopPlayback()
// Disable playback per-sample interrupt.
TIMSK1 &= ~_BV(OCIE1A);
// Disable the per-sample timer completely.
TCCR1B &= ~_BV(CS10);
// Disable the PWM timer.
TCCR2B &= ~_BV(CS10);
digitalWrite(speakerPin, LOW);
pinMode(ledPin, OUTPUT);
while (!sd_raw_init()) {
Serial.println("MMC/SD initialization failed");
startPlayback();
while (true);
