PWM buzzing with attiny13 and a MOSFET
I have an attiny13 driving a logic level MOSFET (IRL530) for controlling the brightness of an LED strip.
My problem is, I hear a buzzing when I change the duty cycle of the PWM on the pin0 with an potentiometer.
The code is quite simple.
int sensor = 3;
int output = 0;
int value = 0;
  pinMode(sensor, INPUT);
  pinMode(output, OUTPUT);
  value = analogRead(sensor);
  analogWrite(output,value/4);
I believe this buzzing is coming from the MOSFET. Most probably the frequency of the PWM signal is roughly in between 20-20.000Hz, so that I can hear it.
However, when I turn the potentiometer completely and give 100% duty cycle to PWM signal, I hear no buzzing. As I get close to the 100% Duty cycle this buzzing slowly fades away.
I think the frequency of the PWM signal should be fixed. So, how does the duty cycle affect the buzzing?
All these aside, I think setting the frequency of the PWM pin higher than 25kHz will make it ultrasonic and I will no longer be able to hear it.
So, how can I change the PWM frequency on the pin0?
Google “secrets of arduino PWM”, there’s a great page on it.
zoom:
Just like you hear when you turn your mains lamp dimmer up and down.
Paul__B:
Ain't is supposed to be the frequency which leads to buzzing. Duty cycle is only the percentage of the high level signal in one period. So, when I turn the potentiometer, I only change the duty cycle, not the frequency. So, if the frequency is not audible already, it should be so for the whole duty cycle range from 0% to 100%.
What am I missing?
At zero, it never switches on, so no buzz. At 100%, it never switches off, so no buzz. Maximum buzz would presumably be around 50%, wouldn't it?
Oh, now as you move through the switching range, the shape of the square wave (or chopped sine wave in a mains dimmer) varies, so the harmonics of the sound changes, giving it different musical tones.
Paul__B:
Got it! Thank you.
