Hey guys, i have a small problem, i need a pwm but my analog values are not a 0-5V, my lowest value are 2 volts and highest is 3 volts.For 2 volts i must have a 0% duty cycle, for 3 volts full 100% duty cycle, i don't have any idea how to make it?
PaulRB:
Hi, try this:
Hi Paul, but i have opposite problem, voltage which control arduino is between 2 and 3 volts , for 2 volts on a analog in must have a 0% duty cycle for 3 volts on a analog in must be 100% duty cycle. For example this work perfekt but vrom 0 to 1 volts
int ledPin = 3; // LED connected to digital pin 9
int analogPin = 0; // potentiometer connected to analog pin 3
int val = 0; // variable to store the read value
pinMode(ledPin, OUTPUT); // sets the pin as output
val = analogRead(analogPin) / 4 ; // read the input pin
if (val < 50)
analogWrite (ledPin, LOW);
if (val > 55)
analogWrite (ledPin, (val / 2) );
I'm sorry but I am finding your question, and your sketch very difficult to understand.
can I suggest you take a look at the map () function.
Paul
