Hello, I am an electronics technician and made a circuit to drive a 5A 12V motor. I need it to rotate only for one sense, but I need to control the speed. I'm using PWM for this.
I've done a circuit for that. When the engine is without load, works normaly at high, medium and low speed rotation, but when I place load, the engine at high speed rotates normal, but at medium speed and low the engine stop after 1 second turning.
I am using the IRF3205 Mosfet with a 4427 drive CI.
What may be happening? The engine with load for the medium and low speed.
I am sharing the circuit for you to help me identify the error.
I'm using 150 (high), 65 (medium) and 45 (low) pwm. Is it little for the motor?
