Hello everyone :),
I am writing to ask you for a suggestion.
In my project, I will need to drive through PWM signals 5/6 RGBA LEDs with a maximal forward current of 500 mA.
I would need to calibrate the DC of the PWM train to precisely set the luminance of each color channel of the LEDs to obtain a background light stimulus and then one RGBA at a time would provide a different light spectrum changing the DC of the 4 color channels.
I will start calibrating the current only in one RGBA LED and after that, I will repeat the circuit for the other LEDs.
I would therefore need several individual PWM signals. I have at home some PCA9685 boards, each one characterized by 16 PWM outputs ( 4 RGBA LEDs ). However, the current output provided is 25mA.
May I connect a transistor together with resistors to the PCA9685 board to drive the LEDs with a higher current exploiting the full 500mA of the LED?
Are there typical LED drivers to use together with the PCA9685 to drive high-power LEDs?
If you have other smarter suggestions to drive these LEDs obtaining a precise regulation of the current through PWM, please, let me know.
And.. thank you for your time! ![]()
