All I'm getting is max speed no matter what I enter.
int pwmPin = 4;
pinMode( pwmPin, OUTPUT);
void loop () {
analogWrite(pwmPin, 300);
delay(5000);
analogWrite(pwmPin, 1000);
delay(5000);
int pwmPin = 4;
void loop () {
delay(5000);
delay(5000);
Try with 3,5,6,9,10,11, the analogWrite()/PWM capable pins.
Syntax:
analogWrite(pin, value)
Parameters:
pin: the Arduino pin to write to. Allowed data types: int.
value: the duty cycle: between 0 (always off) and 255 (always on). Allowed data types: int.
Thanks for answering a dumb question in a helpful manner.
Cheers.
Also, analogWrite() only uses 0 to 255. Anything higher gets cut off.
300 = 0x012C, only the lower 8 bits are used, so 0x2C = 44 decimal
Same for 1000, = 0x03e8 -> 0xe8 = 232 decimal.
