PWM frequency change
I am new to arduino and am trying to code a vibrating motor to vibrate at 100Hz, how do I go about changing the PWM so thats frequency is the value i want?
Thanks
If you provide some information about the motor and how you are controlling it, perhaps someone can guess an answer.
http://www.righto.com/2009/07/secrets-of-arduino-pwm.html
http://playground.arduino.cc/Code/PwmFrequency
http://arduino-info.wikispaces.com/Arduino-PWM-Frequency
If you really need 100Hz for it, rather than bit-banging or using a timer manually, you could consider the 'PWM Frequency Library'. Frequencies from 1Hz to 2MHz are possible.
The library:- 'PWM Frequency Library'
The Arduino documentation:- 'PWM Frequency Library' documentation
If its a rotary eccentric-mass motor then you'l have to experiment to find the drive level that takes it to 100Hz (ie 6000 rpm). It will depend a lot on the mechanical mounting of the motor.
