PWM Glitch using ATiny85
Hi all,
I'm using a ATiny85 to generate 3 different frequencies: 500hz, 1Khz & 2Khz.
I'm using the Fast PWM mode to ahieve this. My problem is the trailing adge of each PWM is moving randomly (as seen on my scope). The fluctuations are as follows for each frequency: 500Hz = 200uS, 1Khz = 100uS & 2Khz =50uS. The datasheet mentions these glitches but I'm not sure how to remedy this problem.
    ATtiny85
                           -------u-------
       RST - A0 - (D 5) --| 1 PB5   VCC 8 |-- +5V
  500Hz SW I/P A3 - (D 3) --| 2 PB3   PB2 7 |-- (D 2) - A1  --> 10K Potentiometer
  1kHZ SW I/P  A2 - (D 4) --| 3 PB4   PB1 6 |-- (D 1) - PWM --> Damper Circuitry
                   Gnd ---| 4 GND   PB0 5 |-- (D 0) - PWM --> 2Khz SW I/P
// normal delay() won't work anymore because we are changing Timer1 behavior
// Adds delay_ms and delay_us functions
#include <util/delay.h>
// Clock at 8mHz
#define F_CPU 8000000  //F_CPU 8000000 (8Mhz). This is used by delay.h library
const int PWMPin = 1;  // Only works with Pin 1(PB1)
const int PotPin = A1;
const int fivehundredhertz_select = 3;
const int onekilohertz_select = 4;
const int twokilohertz_select = 0;
// variables will change:
int selectionState1 = 0;// variable for reading the 500Hz selection
int selectionState2 = 0;// variable for reading the 1KHz selection
int selectionState3 = 0;// variable for reading the 2KHz selection
  pinMode(PWMPin, OUTPUT);
  pinMode(fivehundredhertz_select, INPUT);
  pinMode(onekilohertz_select, INPUT);
  pinMode(twokilohertz_select, INPUT);
  //Use FAST PWM
  TCCR0A = 1 << COM0B1 | 0 << COM0B0 | 1 << WGM01 | 1 << WGM00;
  TCCR0B = 1 << WGM02;
     8 000 000 / 64 = 125 kHz
    64 - pre-scaler
    125 kHz / 63 ~ 2000 Hz
    63 - OCR0A
  // disable interrupts
  TIMSK = 0;
  // set TOP to generate ~2 kHz
  OCR0A = 63;// 63=2Khz, 127=1Khz, 500hz=255
  // 50% duty cycle
  OCR0B = 31;//31
  // start timer at 125 kHz (8 MHz / 64)
  TCCR0B = 1 << WGM02 | 0 << CS02 | 1 << CS01 | 1 << CS00;
  int in, out;
  in = analogRead(PotPin);
  //  out = map(in, 0, 1023, 0, 63);//(in, 0, 1023, 0, 1023) LINE ADDED
  // read the state of the input selections:
  selectionState1 = digitalRead(fivehundredhertz_select);
  selectionState2 = digitalRead(onekilohertz_select);
  selectionState3 = digitalRead(twokilohertz_select);
  if (selectionState1 == HIGH)
    OCR0A = 255;//500 hz
    out = map(in, 0, 1023, 0, 255);//(in, 0, 1023, 0, 255)
    ;//Do nothing
  if (selectionState2 == HIGH)
    OCR0A = 127;//1Khz(127)
    out = map(in, 0, 1023, 0, 127);//(in, 0, 1023, 0, 127)
    ;//Do nothing
  if (selectionState3 == HIGH)
    OCR0A = 63;//2Khz 63
    ;//Do nothing
    if ( out < 0.5 )  pinMode(PWMPin, INPUT);   // This was added due to duty cycle only reaching as low as 1% min.
    else pinMode(PWMPin, OUTPUT);
    OCR0B = out;
    _delay_ms(200);
Any help would be most appreciated!
Thanks
The data sheet suggests to use Phase and Frequency Correct PWM mode to prevent glitches by a buffered update of the OCR1x register.
Would I still be able to get up to 2Khz PWM using phase correct PWM mode? I used fast PWM mode as I think the ATiny default was 500Hz?
Did you read the data sheet how the PWM frequency is generated (prescaler, TOP)?
