PWM help needed to set the pwm to start at certain temprature
Hi
I have the code below it works fine but i would like the pwm to be at 255 until the temperature gets to
55 c
and then run the code i have if temperature is greater than 55
this part of my code i can't get to work but it does compile
if (temp <=0)
analogWrite(hho, val /255);
lcd.print(hhoLCD);
else if (temp >= 55)
thanks in advance
#include <Wire.h>
#include <max6675.h>
#define csTC1 10
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
int thermoDO = 8; //so
int thermoCS = 9; //cs
int thermoCLK = 10; //ss
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
int vccPin = 3;
int gndPin = 2;
int tempPin = A1; // the output pin of LM35
int hho = 11; // the pin where fan is
int temp;
int tempMin = 0; // the temperature to start the fan
int tempMax = 73; // the maximum temperature when fan is at 100%
int hhoSpeed;
int hhoLCD;
float vout = 0.0;
float vin = 0.0;
float R1 = 30000.0; // resistance of R1 (100K)
float R2 = 7500.0; // resistance of R2 (10K)
int value = 0;
int mVperAmp = 66; // use 100 for 20A Module and 66 for 30A Module
int RawValue = 0;
int ACSoffset = 2500;
double Voltage = 0;
int val = 0;
double Amps = 0;
const int analogIn = A0;
uint8_t degree[8] = {140, 146, 146, 140, 128, 128, 128, 128};
pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
pinMode(hho, OUTPUT);
pinMode(tempPin, INPUT);
lcd.begin(20, 4);
lcd.createChar(0, degree);
(Voltage, 2);
temp = readTemp();
if (temp <=0)
lcd.print(hhoLCD);
else if (temp >= 65)
hhoSpeed = map(temp, tempMax, tempMin, 0, 255); // the actual speed of fan
hhoLCD = map(temp, tempMax, tempMin, 0, 100); // speed of fan to display on LCD
analogWrite(hho, hhoSpeed); // spin the fan at the fanSpeed speed
if ((temp <= tempMaxb) && (temp >= tempMinb)) { // if temperature is higher than minimum temp
hhoSpeed = map(temp, tempMaxb, tempMinb, 0, 255); // the actual speed of fan
hhoLCD = map(temp, tempMaxb, tempMinb, 0, 100); // speed of fan to display on LCD
(Voltage, 2); // the '3' after voltage allows you to display 3 digits after decimal point
lcd.print("Temp ");
lcd.print(temp); // display the temperature
lcd.print((char)223);
lcd.setCursor(10, 0); // move cursor to next line
lcd.print("Cell ");
lcd.print(hhoLCD); // display the fan speed
lcd.print("%");
lcd.setCursor(0, 1);
lcd.print("Amps "); // shows the voltage measured
lcd.print(Amps, 1);
lcd.setCursor(10, 1);
lcd.print("Volts ");
lcd.print(vin, 2);
lcd.setCursor(0, 2);
lcd.print("Oil ");
lcd.print(thermocouple.readCelsius());
#if ARDUINO >= 100
#else
lcd.print(0, BYTE);
#endif
delay(200);
lcd.clear();
int readTemp() { // get the temperature and convert it to celsius
temp = analogRead(tempPin);
return temp * 0.073328125;
yep that program has lots of problems. Firstly it needs posting in code brackets so we can copy it
lcd has no library, lots of names have not been declared then there's some weird stuff ive never seen before
i copied and pasted it i don't know any other way?
#include <Wire.h>
#define csTC1  10
int hhoon = 7;
int vccPin = 3;
int gndPin = 2;
int temp;
int tempMina = 55;
int tempMinb = 0;   // the temperature to start the fan
int tempMaxa = 73;  // the maximum temperature when fan is at 100%
int tempMaxb = 73;
int hhoSpeed;
int hhoLCD;
float vout = 0.0;
float vin = 0.0;
int value = 0;
int RawValue = 0;
double Voltage = 0;
int val = 0;
double Amps = 0;
  lcd.begin(20, 4);
  (Voltage, 2);
  temp = readTemp();
   if (temp <=0)
   lcd.print(hhoLCD);
    hhoSpeed = map(temp, tempMaxa, tempMina, 0, 255); // the actual speed of fan
    hhoLCD = map(temp, tempMaxa, tempMina, 0, 100); // speed of fan to display on LCD
  lcd.print("Temp ");
  lcd.print("Cell  ");
  lcd.print("%");
  lcd.print(Amps, 1);
  lcd.print(vin, 2);
  lcd.print("Oil  ");
#if ARDUINO >= 100
#else
  lcd.print(0, BYTE);
#endif
  delay(200);
  lcd.clear();
 (Voltage, 2);
What do you (incorrectly) think that is doing?
 temp = readTemp();
   if (temp <=0)
Get your damned enter key fixed.
This is just to be irritating, right?
More useless crap.
It's called LEARNING.
