I am trying to use the port D45 like a PWM port, it is a PWMH6 port (it appear in ATSAM3X8E datasheet document), but if I try generate a PWM in this pin, it works like a normal digital pin. Can I use it like a PWM using low level instructions? What instructions are there to make it work ?
DUE-specs:
PWM: Pins 2 to 13
Provide 8-bit PWM output with the analogWrite() function. the resolution of the PWM can be changed with the analogWriteResolution() function.
