PWM in DC motor
I wrote this program to control the motor direction and speed.
int pinp = 11;
int pin1 = 10;
int pin2 = 9;
  pinMode(pinp, OUTPUT);
  pinMode(pin1, OUTPUT);
  pinMode(pin2, OUTPUT);
    digitalWrite(pin1, LOW);
  digitalWrite(pin2, HIGH);
  analogWrite(pinp,250);
i used L293D IC for H bridge. i connected pin number 1 to 11 in Arduino, and 8 to 5V in Arduino respectively . when i change the value in analogWrite there is no change in output speed, the motor kept running even i changed the value to "0".
my questions are,
what is the problem actually, is there any problem in my connection and should i connect any external power supply to pin number 8 instead of 5V from Arduino for PWM
kishorekumar:
You connect pin 1 (Enable 1) of the L293D to Pin 11 of the Arduino.
You connected pin 8 (Vs) of the L293D to +5 of the Arduino.
How are the other 14 pins connected?
L293D Arduino
1 11
2 10
3 motor
4 GND
5 GND
6 motor
7 9
8 5V
HI, a circuit diagram of your project would help a lot.
A CAD drawing or a picture of a hand drawn circuit in jpg, png or pdf format is fine.
Tom… :slight_smile:
You might give some information about the motor and how the motor power is connected as well.
[/quote]
I've been using the L293D a lot recently and I suggest you connect PIN8 to an external source (not the arduino). Remember that connecting a motor direclty to arduino is a very good way to fry it!
You should swap arduino pins 10 and 11 so L293-Pin-1 goes to arduino pin 10.
and L293-Pin-2 => arduino d11
Also, connect leds to pins 9,10 and 11 of arduino with 220 ohm resistors so you can see the signal states.
Your biggest mistakes is that L293 PIN-8 IS MOTOR POWER NOT LOGIC POWER !!!
PIN -16 OF L293 IS LOGIC POWER !
DIDN’T YOU EVEN LOOK AT THE DATASHEET ?
l293d.pdf (372 KB)
