PWM in smaller increments to dimm ledstrip
@Dlloyd, Thx, missed your post. Will try it out but don't understand how using analogwrite can accept a smaller value than 1 and thus dimming less than 1 by playing with the dutycycle. (Probably out of my league :)
By playing with the duty cycle (creating a 1 count jitter that follows 8 different patterns) we get 8 more steps of brightness for each original step in duty cycle, so we end up with 11-bit control range.
I thought I'd give it a try ... just connect a super-bright LED to pin 13 (I used red with 1K resistor). I created test code that increases the brightness from 0 - 24 in one second intervals, then repeats. The actual duty cycle value the PWM will see is 0 - 3 with +1 jitter pattern.
I could see 24 distinct and steady changes in brightness, whereas originally there would only be 3.
Give it a try:
unsigned short val = 0; // 0-2047 (brightness range)
const long interval = 1000;
unsigned long previousMillis = 0;
  pinMode(13, OUTPUT);
  analogWrite(13, duty());
  if (currentMillis - previousMillis >= interval) {
    val += 1;
    (val > 24) ? val = 0 : val;
unsigned short duty () {
  byte fine[] = {B0, B1, B00010001, B01001010, B01010110, B01101011, B01110111, B11111111};
  unsigned short dty;
  byte mx = millis() % 8;
  (val > 2047) ? val = 2047 : val;
  dty = val >> 3;
  dty += (fine[val & 7] >> mx) & 1;
  (dty > 255) ? dty = 255 : dty;
  return dty;
