I'm using an Arduino Uno to control an LED via two PWM inputs. However, it will only read up one PWM input at a time. If I plug in one signal on input 5 it reads fine, if I plug in one signal on input 7 it reads fine. If I plug in both signals together on inputs 5 and 7 it will only read one of the two.
I've confirmed my signal source is outputting the correct signal, and i've tried two different boards with the same result.
Any thoughts? Not really sure if its a hardware or software issue at this point.
int ch1;
int ch2;
int ch3;
pinMode(5, INPUT);
pinMode(6, INPUT);
pinMode(7, INPUT);
ch1 = pulseIn(5, HIGH, 25000); // Read the pulse width of
ch2 = pulseIn(6, HIGH, 25000); // each channel
ch3 = pulseIn(7, HIGH, 25000);
Serial.print("Channel 1:"); // Print the value of
Serial.println(ch1); // each channel
Serial.print("Channel 2:");
Serial.println(ch2);
Serial.print("Channel 3:");
Serial.println(ch3);
delay(2000); // I put this here just to make the terminal
// window happier
You understand that the calls are sequential, right?
pulseIn(5, HIGH, 25000) will wait for pin 5 to go HIGH, starts timing, then waits for the pin to go LOW and stops timing and if the pin is already high when the function is called, it will wait for the pin to go LOW and then HIGH before it starts counting or return 0 if 25000 microseconds have expired
Only then it will go do the same for pin 6 and next for pin 7
In general it is better to have your return values from the pulseIn() call to be of type unsigned long rather than int depending the length of your pulse. Your int will overflow after 32767 microseconds (in your case this is not a problem because your function will timeout in 25000 microseconds, so you won't see the issue)
--> what does your signal looks like and what do you expect? why do you think it does not work ?
pulseIn does not return a double but an unsigned long. why do you use a double?
Your code would be better like
const byte ch9Pin = 4;
const byte ch10Pin = 5;
unsigned long channel[2]; //Channel input variable
void setup(){
pinMode(ch9Pin, INPUT);
pinMode(ch10Pin, INPUT);
Serial.begin(115200); // why use 9600? any reason to go slower than easily achieved?
void loop(){
channel[0] = pulseIn(ch9Pin, HIGH); // Read the pulse width of channel 9
channel[1] = pulseIn(ch10Pin, HIGH); // Read the pulse width of channel 10
Serial.print("Channel 9: "); // Print the value of of channel 9
Serial.println(channel[0]);
Serial.print("Channel 10: "); // Print the value of of channel 10
Serial.println(channel[1]);
If you use an array for the results you might want to use an array for the pins number
