PWM interrupt for ADC
Can someone please help me?
I want to do an event interrupt, but how can I do it to call ADC_Handler?
int i=0 ;
double average = 0 ;
double average1 = 0 ;
    float value;
    float volt;
    float current;
void setup(){
   tc_setup();
   pwm_setup();
   adc_setup();
/*************  Timer Counter 0 Channel 2 to generate PWM pulses thru TIOA2  ************/
void tc_setup() {
  PMC->PMC_PCER0 |= PMC_PCER0_PID27;                      //TC2 power ON : Timer Counter 0 channel 2 IS TC2
  TC0->TC_CHANNEL[2].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN; // Software trigger TC2 counter and enable
void adc_setup() {
  PMC->PMC_PCER1 |= PMC_PCER1_PID37;                    // ADC power on
  ADC->ADC_CR = ADC_CR_SWRST;                           // Reset ADC
  ADC->ADC_MR =  ADC_MR_TRGEN_EN                       // Hardware trigger select
                  | ADC_MR_TRGSEL_ADC_TRIG5            // Trigger by PWM Event Line 1 PWMイベントライン1をトリガに設定
                  | ADC_MR_PRESCAL(1);                // ここは0でも1でもどっちでも
  ADC->ADC_IER = ADC_IER_EOC7;                          // End Of Conversion interrupt enable for channel 7
  NVIC_EnableIRQ(ADC_IRQn);                             // Enable ADC interrupt
  ADC->ADC_CHER = ADC_CHER_CH7 | ADC_CHER_CH6 | ADC_CHER_CH5;   // Enable Channel 7
void pwm_setup(){
  uint16_t CounterPeriod;
  uint16_t DeadTime;
    //キャリア周波数10Hz、デッドタイム約1.2usの場合の設定
    CounterPeriod = 4200 - 1;
    DeadTime = 100;
   REG_PWM_CPRD0 = CounterPeriod;
   REG_PWM_CPRD1 = CounterPeriod;
   REG_PWM_CDTY1 = 2100;
   REG_PWM_CMR0 = PWM_CMR_CALG | PWM_CMR_CPRE_MCK;
   REG_PWM_CMR1 = PWM_CMR_DTE | PWM_CMR_CALG | PWM_CMR_CPRE_MCK;
   REG_PWM_DT1 = PWM_DT_DTH(DeadTime) | PWM_DT_DTL(DeadTime);
    //PIOのディセーブルレジスタ
    REG_PIOC_PDR = PIO_PDR_P9 | PIO_PDR_P8 | PIO_PDR_P7 | PIO_PDR_P6 | PIO_PDR_P5 | PIO_PDR_P4;
    //ペリフェラルABセレクタ相補にしている
    REG_PIOC_ABSR |= PIO_ABSR_P9 | PIO_ABSR_P8 | PIO_ABSR_P7 | PIO_ABSR_P6 | PIO_ABSR_P5 | PIO_ABSR_P4;
   //AD変換のためのPWMイベントライン設定
   PWM->PWM_CMP[0].PWM_CMPM = PWM_CMPM_CEN;                       // PWM0の比較を有効化
   PWM->PWM_ELMR[1] = PWM_ELMR_CSEL0;                             // PWMイベントライン1にPWM0を設定
   PWM->PWM_CMP[0].PWM_CMPV = PWM_CMPV_CV(CounterPeriod - 10);  // PWM0のDUTYを設定
  NVIC_EnableIRQ(TC2_IRQn);  // TC2 NVIC enable
  NVIC_SetPriority(PWM_IRQn, 0); // PWMコントローラのNVIC(Nested Vector Interrupt Controller)の優先度を0(最高)にする
  NVIC_EnableIRQ(PWM_IRQn); // PWMコントローラをNested Vector Interrupt Controller (NVIC)に接続する。
  PWM->PWM_ENA |= PWM_ENA_CHID1 | PWM_ENA_CHID0; // PWMチャンネルを有効にする
  PWM->PWM_IER1 |= PWM_IER1_CHID0; // イベント割り込みを有効にする
   REG_PWM_IER1 = PWM_IER1_CHID0; // Interrupt on PWM Channel 0 counter
  REG_PMC_PCER1 |= PMC_PCER1_PID36; // PWMの有効化
  REG_PWM_CLK = PWM_CLK_PREA(0) | PWM_CLK_DIVA(1); // PWMクロックレートを84MHzに設定 (84MHz/1)
  PWM->PWM_CH_NUM[0].PWM_CDTY = 50; // PWMのデューティサイクルを50%にする
void loop(){
int x = 0, y=0;
void ADC_Handler(void){
    if (ADC->ADC_ISR & ADC_ISR_EOC7)
     value = ADC->ADC_CDR[7];
Serial.print(value);
https://forum.arduino.cc/t/pwm-triggered-adc-with-event-line/320873/9
Thanks for the reply! I'm sorry, I don't know much about this, but I'm not sure which part of the program can skip to the interrupt destination such as ADC_Handler.
