I found the following code by Runnerup. It's a library to manipulate pwm frequencies.
I've used it before with success on the same Nano r3. Arduino 1.6.1 on a Macbook running os x 10.6.8. It ran fine on earlier versions of the IDE.
I imported it as a zip file, after renaming it to an acceptable form, and all went well until I attempted to run it, when I received the following error:
In file included from pwmFan25k.ino:1:0:
/Users/mihaisofti/Documents/Arduino/libraries/ArduinoPWMLibv_05/PWM.h:36:33: fatal error: utility/BTimerDefs.h: No such file or directory
#include "utility/BTimerDefs.h"
This is the code:
#include "PWM.h"
int32_t frequency =3000; //frequency in Hz
InitTimersSafe();
bool success = SetPinFrequencySafe(9, frequency);
if(success) {
pinMode(13, OUTPUT);
digitalWrite(13, HIGH); //to show that all's well by lighting led13
int sensorValue = analogRead(A0);
pwmWrite(9, sensorValue / 4);
delay(30);
I've tried moving BTimerDefs.h up the hierarchy from '/utility' up one level and changing the path accordingly. I've tried entering #includeBTimerDefs.h at the top, but continue to get the same error.
Can anyone see what's wrong, and could it be changes in the way things should be done in IDE 1.6.1?
Any and all help would be hugely appreciated,
Mihai
