PWM output voltage issues
Hey guys, I've used code to change the frequency of one of my PWM pins to 95 khz and now I'm experiencing issues with the output voltage. I expected the output voltage to be 5v and 0v but I'm actually getting +50mv and -50 mv. Does anyone know how to fix this? I need to have 5v output.
This is the code I used:
#define outpin 10                                  // OC2A pin - cannot be changed
#define clockFrequency 16000000                    // Arduino clock frequency
#define outputFrequency 95000                    // desired output frequency
#define prescaleFactor 1                           // the only choice to get 1 MHz out
void setup ()
  TCCR2B = B00000001;                               // set CS20, clear CS21, CS22 and WGM22
  TCCR2A = B01000010;                               // set COM2A0 and WGM21, clear COM2A1 and WGM20
  OCR2A  = ((float)clockFrequency / (outputFrequency * 2 * prescaleFactor)) -1;  // timer data
  pinMode(outpin, OUTPUT);                          // turn on output pin
// the timer runs with no additional code and no use of interrupts
// do whatever else you want to do here
void loop ()
No you are not.
It is probably an artifact of how you are measuring it.
What are you doing to measure it?
I actually fixed it, you were right, I was measuring it wrong. Thanks for the reply!
