Hello: First, I hope I have the correct forum. I'm using a Nano. I would like to fade 4 LEDs * and *use two servos on pins 3,5,6,9 and 10, 11. The fade on pin 9 or 10 or 11 will not work unless I comment out all servo references in the code. I just read in another forum that the Servo library disables analogWrite on 9 and 10, but I can't get 11 to work either. So, is there any way around this? Code below, if it helps.
[code]
// Steambox Sketch
#define INTERVAL_1 0
//#include<Servo.h>
unsigned long time_1 = 0;
int count = 0;
//int gearservo = 10;
//Servo Servogear;
//Servo Servolock;
int pos = 0;
const int LED_Y = 2; //digital pins
const int RGB_R = 4;
const int RGB_G = 7;
const int RGB_B = 8;
const int LED_W = A3; //Used as a digital pin
int LED_B1 = 3; //PWM for fading LEDS
int LED_B2 = 5;
int LED_B3 = 6;
int LED_B4 = 9;
const int LED_E = 12; //Emerald LED
const int Button = 13; //button pin
int LEDS = 0;
int buttonState = 0;
pinMode(LED_Y, OUTPUT);
pinMode(RGB_R, OUTPUT);
pinMode(RGB_B, OUTPUT);
pinMode(RGB_G, OUTPUT);
pinMode(LED_W, OUTPUT);
pinMode(LED_B1, OUTPUT );
pinMode(LED_B2, OUTPUT );
pinMode(LED_B3, OUTPUT );
pinMode(LED_B4, OUTPUT );
pinMode(LED_E, OUTPUT);
pinMode(Button, INPUT);
//Servogear.attach(10);
/// Servolock.attach(11);
//Servolock.write(90);
switch (LEDS) {
//___________ Yellow LED blink______________________________________
case 0:
for (int y = 0; y <= 3; y++) { //blink 3 times
digitalWrite (LED_Y, HIGH);
delay(150);
digitalWrite (LED_Y, LOW);
delay(150);
digitalWrite(LED_Y, HIGH); //stay high for 1.5 seconds
delay(1500);
digitalWrite(LED_Y, LOW);
delay (100);
case 1:
//_----------------RBG Tube----------------------------------
digitalWrite(RGB_R, HIGH); //RGB TUBE Cycle through red, blue, green
digitalWrite(RGB_R, LOW);
digitalWrite(RGB_G, HIGH);
digitalWrite(RGB_G, LOW);
digitalWrite(RGB_B, HIGH);
digitalWrite(RGB_B, LOW);
//-------------White Blink ON------------------------------
for (int w = 0; w <= 2; w++) { //Whte blink quickly twicw
digitalWrite (LED_W, HIGH);
delay(100);
digitalWrite (LED_W, LOW);
delay(100);
digitalWrite(LED_W, HIGH); // stay on 1.5 seconds
delay(1500);
digitalWrite(LED_W, LOW);
case 2: //Blue 1 to 2
//-----------Blue 1 to 2 -----One-----------------
if (millis() >= time_1 + INTERVAL_1) { //LED 1 fade in and out
time_1 += INTERVAL_1;
for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += 5) {
analogWrite(LED_B1, fadeValue); //fading up to 255
delay(25);
for (int fadeValue = 255 ; fadeValue >= 5; fadeValue -= 3) { //Stay on at very low brightness
delay(25);
if (millis() >= time_1 + INTERVAL_1) { //LED 2 fede in and out
analogWrite(LED_B2, fadeValue); //fading up to 255
delay(25);
delay(25);
analogWrite(LED_B1, LOW); //B1 turn completely off
case 3: // blue 2 to 3
//---------------------2 to 3 -----------------------------
delay(25);
for (int fadeValue = 255 ; fadeValue >= 5; fadeValue -= 5) {
delay(25);
analogWrite(LED_B3, fadeValue); //fading up to 255
delay(25);
delay(25);
analogWrite(LED_B2, LOW); //B1 off
digitalWrite(LED_B3, LOW);
case 4:
//----------------Emerald------------------------
digitalWrite(LED_E, HIGH);
delay( 4000);
digitalWrite(LED_E, LOW);
case 5:
//------------------3 to 2-------------------------
delay(25);
delay(25);
delay(25);
delay(25);
analogWrite(LED_B3, LOW); //B1 off
//-----------------2 to 4-------------------------
case 6:
delay(25);
delay(25);
analogWrite(LED_B4, fadeValue); //fading up to 255
delay(25);
delay(25);
case 7:
analogWrite(LED_B4, LOW);
delay (2000);
digitalWrite(LED_W,LOW);
[/code]
