pwm pins won't work as normal digital pins
hi all,
I have a Arduino Duemilanove (Updated 328 Version) connected with flash using as3.I am using the digital pins to simply switch on a relay ie. just switch the power high.
However I need 8 pins for 8 relays, digital pins 0 and 1 are used for the flash to arduino connection, I am already using digital pins 2-7 and they work fine. I am however 2 pins short. I have tried to use pins between 8 and 13 but these all seem to be pwm pins.
I can get these pwm pins to fade a led up and down by calling them in flash as their pwm pins. However I want to use them as just ordinary digital pins, I have been told and have seen other peoples code which simply acess pins 8-13 just like they have accessed pins 2-7 using:
var ledPin:Number = 3; arduino.setPinMode(ledPin, Arduino.OUTPUT); arduino.writeDigitalPin(ledPin, Arduino.LOW);
When I try to use one of these pwm pins as a normal digital pin eg. change the:
to something like
var ledPin:Number = 8;
and change the wiring according on my board it does nothing.
I am thinking it is something to do with my firmdata maybe but I can't find one which allows me to referance the pwm pins as normal digital pins.
I had heard that maybe baud rates was to blame but im really stumped.
any help would be much appreciated
oh btw the firmdata I have been trying are the ones supplied with arduino-017 and also the glue ones
regards booba23
Don't worry guys I answered my own question, I just make the pwm power 255 to equal on and 0 to equal off
regards booba23
Keep in mind that the Arduino analog pins are also avalible to be used as digital pins. Just address them as pins digital pins 14-19.
Lefty
I have read that, was indeed the case but whilst to trying to figure out my problem I did try that referencing the analog pins as 14-19 but it didn't work.
Possible because I am accessing them through flash and not actually coding it in the arduino code.
Any how I have it working, but thx for the suggestion, if I need a lot of pins in another project i will definately check out that possibility
regards booba23
