PWM-problem [Motor control interface with Processing + Standard Firmata]
Hello Community,
at the moment I am working on a motor control Interface with Processing 2.x and Standard Firmata for testing purposes in a project in my apprenticeship as electronic technician for automation Technology. We have to construct a (machine) tool from scratch and have to build it.
It´s working pretty fine already but I noticed one problem and poorly can´t find the error source.
I use a Arduino UNO for development but in the tool i will use the MEGA 2560 since I need a lot more I/O´s.
The error is:
PWM on Pin 10 isn´t working as it should. It does nothing unless the PWM value is = 255 where it turns to HIGH from LOW as it should but below 255 it stays LOW.
(maybe the Firmata-library uses the timer that controls pin 10? Do I have a mistake in my Code?)
I hope that somebody can help me
Best regards,
Eatex
Processing-Code: (sorry for no comments at the Moment, if you have some questions just ask)
import processing.serial.*;
import cc.arduino.*;
import controlP5.*;
ControlP5 controlP5;
Arduino arduino;
int Motor_Speed;
boolean direction;
boolean state_brake;
int servoAngle = 90;
int[] pinPWM = {
  3, 11, 10, 0, 0
int[] pinBrake = {
  9, 8, 0, 0, 0
int[] pinDirection = {
  12, 13, 0, 0, 0
int Motor_speed_M1 = 0; // you can change to set a starting value
int Motor_speed_M2 = 0;
int Motor_speed_M3 = 0;
int Motor_speed_M4 = 0;
int Motor_speed_M5 = 0;
boolean direction_M1 = true; // 0: backward, 1: forward
boolean direction_M2 = true;
boolean direction_M3 = true;
boolean direction_M4 = true;
boolean direction_M5 = true;
boolean state_brake_M1 = false;
boolean state_brake_M2 = false;
boolean state_brake_M3 = false;
boolean state_brake_M4 = false;
boolean state_brake_M5 = false;
int[] y_value_slider = {
  10, 90, 170, 250, 330, 410
int[] y_value_radio = {
  60, 140, 220, 300, 380
  size(400, 600);
  println(Arduino.list());
  arduino = new Arduino(this, Arduino.list()[1], 57600);
  for ( int i = 0; i <= 13; i++ ) {
    if ( i == 10 ) arduino.pinMode( i, Arduino.PWM );
    else if ( i == 6 ) arduino.pinMode( i, Arduino.SERVO );
    else arduino.pinMode( i, Arduino.OUTPUT );
  controlP5 = new ControlP5(this);
  for (int Mnum=0; Mnum<5; Mnum++) {
    controlP5.addToggle("direction_M"+(Mnum+1), true, 20, y_value_radio[Mnum]-10, 10, 10);
    controlP5.addToggle("state_brake_M"+(Mnum+1), false, 200, y_value_radio[Mnum]-10, 10, 10);
    controlP5.addSlider("Motor_speed_M"+(Mnum+1), 0, 255, 0, 20, y_value_slider[Mnum], 255, 20);
  controlP5.addSlider("servoAngle", 30, 150, servoAngle, 20, y_value_slider[5], 180, 20);
void draw() {
  arduino.servoWrite(6, servoAngle);
  for (int Snum = 0; Snum <5; Snum++) {
    if (Snum==0) {
      Motor_Speed = Motor_speed_M1;
      state_brake = state_brake_M1;
      direction = direction_M1;
    if (Snum==1) {
      Motor_Speed = Motor_speed_M2;
      state_brake = state_brake_M2;
      direction = direction_M2;
    if (Snum==2) {
      Motor_Speed = Motor_speed_M3;
      state_brake = state_brake_M3;
      direction = direction_M3;
    if (Snum==3) {
      Motor_Speed = Motor_speed_M4;
      state_brake = state_brake_M4;
      direction = direction_M4;
    if (Snum==4) {
      Motor_Speed = Motor_speed_M5;
      state_brake = state_brake_M5;
      direction = direction_M5;
    arduino.analogWrite(pinPWM[Snum], Motor_Speed);
    if (state_brake) {
      arduino.digitalWrite(pinBrake[Snum], 1);
    } else arduino.digitalWrite(pinBrake[Snum], 0);
    if (direction) {
      arduino.digitalWrite(pinDirection[Snum], 1);
      arduino.digitalWrite(pinDirection[Snum], 0);
Pins 0 and 1 are the hardware serial pins. Hardware serial is how processing and the Arduino communicate. Stop f**king with them.
It’s stupid to have a for loop that does something different each iteration.
Its stupid to be trying to PWM pin 0.
Or to be trying to do anything else to pin 0.
There are only 3 valid values in your pin number arrays, so quit (uselessly) looping 5 times.
PaulS:
It's stupid to have a for loop that does something different each iteration.
Thank you for your advise, PaulS! :slight_smile:
I´ve corrected those programming mistakes but i couldn´t find a solution for:
How would you do it in this situation? The ControlP5-Library can´t work with Arrays so I have to save the values as a single variable and execute them in a for-loop. At least with my current programming skills I didn´´t found a better solution. Can you show me a better solution to improve my skills in the future, please?
for (int Snum = 0; Snum <3; Snum++) {
    if (Snum==0) {
    if (Snum==1) {
    if (Snum==2) {
    if (Snum==3) {
    if (Snum==4) {
    if (state_brake) {
    if (direction) {
unfortunately, the problem I have is still not solved.
Pin 10 still just changes to HIGH when PWM value is >=255, below it stays LOW.
Greetings,
EATEX
If I asked you to go to the grocery store, stop by the train station, buy gas, see a movie, and pet a dog, would you try to use a for loop to do that? Of course not. None of the things to do are related.
You don’t need a for loop, either.
PaulS:
You don't need a for loop, either.
That is quite true, PaulS.
If I have understood correctly , you would say that this is the better solution?:
arduino.analogWrite(pinPWM[0], Motor_speed_M1);
if (state_brake_M1) {
  arduino.digitalWrite(pinBrake[0], 1);
} else arduino.digitalWrite(pinBrake[0], 0);
if (direction_M1) {
  arduino.digitalWrite(pinDirection[0], 1);
} else arduino.digitalWrite(pinDirection[0], 0);
arduino.analogWrite(pinPWM[1], Motor_speed_M2);
if (state_brake_M2) {
  arduino.digitalWrite(pinBrake[1], 1);
} else arduino.digitalWrite(pinBrake[1], 0);
if (direction_M2) {
  arduino.digitalWrite(pinDirection[1], 1);
} else arduino.digitalWrite(pinDirection[1], 0);
arduino.analogWrite(pinPWM[2], Motor_speed_M3);
if (state_brake_M3) {
  arduino.digitalWrite(pinBrake[2], 1);
} else arduino.digitalWrite(pinBrake[2], 0);
if (direction_M3) {
  arduino.digitalWrite(pinDirection[2], 1);
} else arduino.digitalWrite(pinDirection[2], 0);
Yes.
Thank you Paul!! :slight_smile:
I think that I´m thinking too complicated often and therefore overlook the simplest solution :confused:
But I still got this Problem with the PWM on Pin 10 :frowning:
I´ve tried every pinMode that the Standard-Firmata-Library offers. I´ve tried digitalWrite(), servoWrite() and analogWrite()...but it´s always the same result, Pin 10 just works LOW or HIGH and does not send PWM-Signals as it should actually.
This is confusing me. It´s also no Hardware issue, I´ve already tested it via a Arduino Programm and there it works properly...
Nobody knows a solution for this?
I found the Problem :slight_smile:
I didn´t know that the Servo.h library disables the analogWrite()-function on Pin 9 and 10 at boards other than the Mega but also didn´t expect that this library is the troublemaker ^^
Thank you guys!
Greetings,
EATEX
Fine, now I´m using my MEGA2560R3 and it works :slight_smile:
But now, after I included a Timer Interrupt with Timer5 to check my sensor states every x-millis, I got the same issue with Pin 11 as i had with Pin 10 at the Uno...It´s not a big Problem because i have enough alternative PWM Pins on the MEGA but I ask me from where this issue comes now. As far as I know, Timer 5 has nothing to do with Pin 11.
Can somebody explain me this issue, please?
Greetings,
EATEX
