im not sure if this is in the correct area but how is it possible to set the PWM frequency to 25k. I have seen a few examples but to be honest they confuse me somewhat. What is the simplest way to go about this?
Secondly, are you able to run multiple fans off the same PWM pin if you want the same Duty Cycle and each fan has its 12v supplies going to them?
Dylfish:
Change the timer prescaler value. It's in the datasheet, look at the registers for the timers. You want TCCRnB.
Dylfish:
There'll be a way, yes, but our telepathic powers are weak so you'll to come up with a lot more information than that.
This is the code I used for driving PC fans on a Uno. Use this code in setup:
// Only timer/counter 1 is free because TC0 is used for system timekeeping (i.e. millis() function),
// and TC2 is used for our 1-millisecond tick. TC1 controls the PWM on Arduino pins 9 and 10.
// However, we can only get PWM on pin 10 (controlled by OCR1B) because we are using OCR1A to define the TOP value.
// Using a prescaler of 8 and a TOP value of 80 gives us a frequency of 16000/(8 * 80) = 25KHz exactly.
TCCR1A = (1 << COM1B1) | (1 << COM1B0) | (1 << WGM11) | (1 << WGM10); // OC1A (pin 9) disconnected, OC1B (pin 10) = inverted fast PWM
OCR1AH = 0;
OCR1AL = 79; // TOP = 79
TCCR1B = (1 << WGM13) | (1 << WGM12) | (1 << CS11); // TOP = OCR0A, prescaler = 8
OCR1BH = 0;
OCR1BL = 80; // max fan speed (i.e. pin 5 initially low all the time)
TCNT1H = 0;
TCNT1L = 0;
Call this code to set the speed:
// Set the fan speed
void setTransistorFanSpeed(uint8_t fanPercent)
OCR1BH = 0;
OCR1BL = (fanPercent * 80u)/100;
PC PWM fans are designed to be driven from an open collector or open drain output, so I drive them from the Arduino pin using an NPN transistor, or 2N7000 mosfet, or an opto isolator if I need isolation. It's safest to use a separate transistor to drive each fan, although the PWM fans I have bought come with cables that just connect the PWM input in parallel with the one for the CPU fan.
