I am generating PWM wave of frequency 62KHz(Fast PWM) and I want to read that PWM wave in my Arduino I use pulseln function to perform this and to read this PWM wave, however, the samples are not read properly is there any way to read a PWM wave at this frequency???
That can be performed by a timer capture, although we don't know what board you are using.
A DUE can capture PWM pulses well above 1 MHz (frequency and duty cycle), I can't tell for an UNO.
Using Arduino UNO.In due should i use pulseln command?
With a DUE, you would program a timer capture (it is pretty easy).
All of which begs the question of why any one would want to do this.
Mark
