PWM: Read square wave signal
Hello everyone,
I want to use pwm pin to generate a square wave signal with duty cycle of 50%.
Simply, I wrote:
analogWrite(pwm pin,128);
I want to read the output value to find when the signal change from 0 to 1.
I have tried to use the digitalRead function, but it doesn't work because I always get the value 0.
I want to get something about this:
0,0,............0,1,1,...............,1,0,0,etc.
The only case that digitalRead works is when the duty cycle is 100% or 0%, namely a constant signal.
Thanks in advance for any help.
Where do you aim to see 0,0,............0,1,1,...............,1,0,0,etc. ?
Why not post what you actually wrote?
Aka cut-and-paste
I didn’t write any code because I don’t know which function use.
Look the image that I attached.
With analogWrite(pwm pin, 128) I generate a square waveform.
I want to read the value of the signal to check if in a certain time the voltage is equal to 5V (HIGH) or 0V (LOW).
Is there some function to do this?
That code cannot possibly compile so WHY DON'T YOU POST THE ACTUAL CODE YOU WROTE?
 pinMode(3, OUTPUT);
 pinMode(13, OUTPUT);
 analogWrite(3,128); // duty cycle 50%
 if(digitalRead(3)==HIGH)
   digitalWrite(13,HIGH);
   digitalWrite(13,LOW);
Go back and edit that. You need to select the code before you tag it.
Edit - thanks... now, what does your code do or not do that is a problem for you?
It's just an example to check if I can read the correct value of pwm pin.
albertoM90:
Right, we know that. What is the result?
The led that I connect to pin 13 is off because the value of digitalRead is always 0. The led doesn't blink.
int digitalRead(uint8_t pin)
	uint8_t timer = digitalPinToTimer(pin);
	uint8_t bit = digitalPinToBitMask(pin);
	uint8_t port = digitalPinToPort(pin);
	if (port == NOT_A_PIN) return LOW;
	// If the pin that support PWM output, we need to turn it off
	// before getting a digital reading.
	if (timer != NOT_ON_TIMER) turnOffPWM(timer);
	if (*portInputRegister(port) & bit) return HIGH;
	return LOW;
albertoM90:
Did you use a current limiting resistor?
No, I don't use any resistors.
The code works, but can you explain me how to read the digital value of a pwm pin?
I want to check the value to do other things.
Thanks.
By jumpering the output pin to an input pin?
Are you getting paid by the line?
digitalWrite(13,digitalRead(3));
albertoM90:
That is a bad idea. You can burn out an Arduino output because it can exceed the maximum output current rating for a pin.
 pinMode(3, OUTPUT);
 pinMode(3,INPUT);
I have tried to jump from output to input adding the line pinMode(3,INPUT), but the situation doesn't change.
 pinMode(3,INPUT);
It may be instructive to look at the source of pinMode.
You are right, but to be honest I'm at the beginning with Arduino and I thought that my question was a simple task to solve.
The best way to learn is to do.
AWOL:
Which is in reply #10. Especially the comments.
