PWM signal corrupted on pin 6 but not pin 5
gonadgranny:
Whenever i have experienced conflicts in the past like when using the servo library for example it makes all of the pins which use the same timer as the library act strangely.
Based on your own experience you are facing an anomalous situation yet you won't post the program that is exhibiting the problem?
...R
