PWM signal is not working
Hello. I have a problem that I can’t get any signal from Pin 9 (Using it as PWM). I am using Arduino Uno. I tested dummy code and it works just fine. Whole code other than analogWrite works just fine. I just couldn’t figure out why this is happening. Thanks for the help!
#include <Servo.h>
Servo myservo;
int trigger = 2;
int valu = 0;
int enable = 7;
int buttonstate = 0;
int lastbuttonstate = 0;
const int pwm = 9;
const int test = 160;
  pinMode(pwm, OUTPUT) ;
  pinMode(trigger, INPUT_PULLUP);
  pinMode(enable, OUTPUT);
  myservo.attach(11);
  digitalWrite(enable, LOW);
  analogWrite(9, 200) ;
  delay(100);
  buttonstate = digitalRead(trigger);
  if (buttonstate != lastbuttonstate)
    valu = digitalRead(trigger);
    int i = 0;
    delay(100);
    if (valu == HIGH)
    { digitalWrite(enable, HIGH);
      Serial.print("b");
      myservo.write(5);
    if (valu == LOW)
      Serial.print("a");
      myservo.write(90);
  lastbuttonstate = buttonstate;
Read this
Then read this:
Installation & Troubleshooting
For problems with Arduino itself, NOT your project
I am sorry that I posted on wrong category, I was unable to delete/move it afterwards. My only problem is that I can't get voltage from pin 9
My only problem is that I can't get voltage from analogWrite
See Servo - Arduino Reference
On boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10, whether or not there is a Servo on those pins.
