First topic (no answer):
US style - car lights (signal lights) - #5 by prologikus - Project Guidance - Arduino Forum
I'm trying to power up my signal lights from my car using a MOSFET with PWM signal from arduino.
There are some modules to do that on the local market but i want to build one not to buy one
The module is originaly set to 50% duty and is connected like so :
3 wires witch needs to be connected:
~1 is connected to the positive wire from the low beams
~2 is connected to one side of the signal lights wire (CUTTED)
~3 is connected to the other side of the cutted wire of the signal lights (from the car)
So, i'll power the signal lights using the low beams wire.
I also need a signal when the LOW-beams are on, in order to send the PWM signal from arduino just when is needed
I used a voltage divider - 30k-13k to get a low voltage even the car give me 16V, a zener diode, in case and also a 100nf cap
initial schematic (not so important): http://i.giphy.com/3o7TKuZGIx4Z7l9iOQ.gif
the circuit
(1,2,3 are the wires that come out of the module)
after soldering it i just realised it is a total fail
to fix the secound schematic i suppose that i need another wire witch will be connected to ground
(witch is not present on the market module)
I'm sorry for english hope you'll understand and give me some informations
