I want to know if PWM signals vary current or voltage. On the net I see various places telling its voltage but if I am using a 5v motor then , wont using pwm signal of 2.5 V make it not rotate as opposed to rotate it slowly, as it requires a voltage of 5v to operate.
And does using PWM sacrifices Torque of the motor as compared to using geared reduction mechanism and is there any estimate to deduce that value.
PWM varies the average voltage. Reducing voltage also reduces current. Most motors will run at much lower voltages than their recommended maximum voltage.
Since reducing speed with PWM reduces the power supplied to the motor then yes it does affect the torque. Gearing effectively multiplies torque while reducing speed. Reducing the power input to the motor with PWM reduces torque and speed.
slipstick and jremington thank you so much. I didn't knew that motors can run at a much lower voltage and about the torque being directly proportional to the current. Btw any idea by how much would the torque reduce or would I have to use a multimeter to calculate it.
A3y4n:
Thanks in advance.
Depends on the mode, slow decay, fast decay, modified fast decay or synchronous rectification, and depends on the PWM frequency v. the motor inductance. No simple answers I'm afraid, except that PWM switches the voltage, current is due to the load. Many modes let the voltage float at parts of the cycle, which is where the complexity comes in. Synchronous rectification never floats and is the easiest mode to analyze.
