PWM Square Wave generator and its complementary
Hello,
I want to generate a square function and its complementary in a range between 20kHz up to 200kHz in Arduino One.
I have tried using the tone function but it is limited to 65kHz. Also, I have not been able to generate a complementary wave which is syncronous with the other (when wave 1 is HIGH, wave 2 is LOW).
I heard that there is a way to generate the complementary wave through the PWM of the microcontroller but I have not found any documentation on how to do it.
Any ideas?
Thanks in advance
Do you want a variable duty cycle or is 50% (as in the tone library) OK ?
Arduino One is the direct English translation from the Italian Arduino Uno ?
