PWM to RS232 Camera Zoom
I have found some code written for Atmel ATmega8535 that is for PWM to RS232 zoom function on a VK-914 camera. What would I have to do to use this code with the Arduino Duemilanove? What language is this written in? Basic?
’ *********************************************************************************** ’ * * ’ * Title : VK-S274 & VK-S274R SERIES Hitachi Block Camera Controller * ’ * Version : 1.1 Beta * ’ * Last Updated : 02.12.2008 * ’ * Target Device : ATMEGA8535 * ’ * Author : Farmtech & Neptune769 * ’ * Support : Try Skype Name : farmtech_dk or in MCS Bascom Forum * ’ * Program code : BASCOM AVR * ’ * Hardware req. : VK-S274 or VK-S274R SERIES Hitachi Block Camera * ’ * Description : Control : Zoom - Focus & Iris Via Serialport on Camera * ’ * Baud for camera : 4800.8.E.1 : Even Parity default for camera * ’ * : 9600.8.N.1 but need setup in Camera (:WE05EF0) * ’ * *********************************************************************************** $regfile = “m8535.dat” $crystal = 8000000 $hwstack = 40 $swstack = 30 $framesize = 60 Open “comd.2:4800,8,e,1” For Output As #1 ’ 4800 bps , even Parity ; default for camera 'Config Ports for the 6 buttons n PortC we use buttons to GND Config Portc.0 = Input : Set Portc.0 'Zoom NEAR Button Config Portc.1 = Input : Set Portc.1 'Zoom FAR Button Config Portc.2 = Input : Set Portc.2 'Focus NEAR Button IN Config Portc.3 = Input : Set Portc.3 'Focus FAR Button OUT Config Portc.4 = Input : Set Portc.4 'Iris offset (average) + Button Config Portc.5 = Input : Set Portc.5 'Iris offset (average) - Button Config Portc.6 = Input : Set Portc.6 'Freeze ON / OFF Toggle Button 'Config Portc.7 = Input : Set Portc.7 'not used yet Button Dim I As Byte , Irish As Byte , Irisl As Byte , Irisavg As Byte , Freezebit As Byte 'Print Version() 'setup Camera Print #1 , “:WFCCB01” ’ Switch the continuous digital zoom ON Waitms 10 Print #1 , “:WFDFC10” ’ Zoom speed normal Waitms 10 Print #1 , “:WFCCB40” ’ Switch the instant digital zoom ON Waitms 10 Print #1 , “:WFCBBA8” ’ Auto focus ON allways (not on manual Focus) 'setup Iris offset (average) level Irisavg = &H40 ’ Iris is normal hex 40 i hope Irish = 0 ’ Bit set for Iris to HIGH Irisl = 0 ’ Bit set for Iris to LOW Freezebit = 0 ’ togglebit for freez images Wait 1 'The main program Do If Pinc.0 = 0 Then Print #1 , “:WFCBB99” ’ zoom near Bitwait Pinc.0 , Set ’ wait for button relace Print #1 , “:WFCBBFE” ’ stop Print #1 , “:WFCBBA8” ’ Auto focus on Waitms 300 ’ wait for auto zoom to get focus End If If Pinc.1 = 0 Then Print #1 , “:WFCBB9B” ’ zoom far Bitwait Pinc.1 , Set ’ wait for button relace Print #1 , “:WFCBBFE” ’ stop Print #1 , “:WFCBBA8” ’ Auto focus on Waitms 300 ’ wait for auto zoom to get focus End If If Pinc.2 = 0 Then Print #1 , “:WFCBBFE” ’ Auto focus off Print #1 , “:WFCBBAA” ’ focus near Bitwait Pinc.2 , Set ’ wait for button relace Print #1 , “:WFCBBFE” ’ stop End If If Pinc.3 = 0 Then Print #1 , “:WFCBBFE” ’ Auto focus off Print #1 , “:WFCBBA9” ’ focus far Bitwait Pinc.3 , Set ’ wait for button relace Print #1 , “:WFCBBFE” ’ stop End If 'Iris offset (average) level + Open If Pinc.4 = 0 And Irish = 0 Then 'if pinc.4 and irisbit high is 0 else skip Irisl = 0 ’ reset to low bit I = Irisavg + 1 ’ to start from known pos For I = Irisavg To 255 ’ Irisavg to High 00 - FF Print #1 , “:WFD9E” ; Hex(i) 'Iris offset (average) send Irisavg = I ’ put I count into Irisavg If I = 255 Then ’ If MAX Iris then exit for Irish = 1 ’ Set Iris bit TO high so it dont do the OPEN until you have closed it a bit Exit For End If If Pinc.4 = 1 Then Exit For ’ check for button relace Next ’ next i End If 'Iris offset (average) level - Close If Pinc.5 = 0 And Irisl = 0 Then ’ if pinc.5 and irisbit low is 0 else skip Irish = 0 ’ reset to high bit I = Irisavg ’ to start from known pos For I = Irisavg To 0 Step -1 ’ from Irisavg to MIN FF - 00 Print #1 , “:WFD9E” ; Hex(i) ’ Iris offset (average) send Irisavg = I ’ put I count into Irisavg If I = 0 Then ’ If MIN Iris then exit for Irisl = 1 ’ Set Iris bit TO low so it dont do the CLOSE until you have open it a bit Exit For End If If Pinc.5 = 1 Then Exit For ’ check for button relace Next ’ next i End If If Pinc.6 = 0 And Freezebit = 0 Then Print #1 , “:WFF3301” 'Freeze Field ON Freezebit = 1 'set freezebit to freeze OFF Bitwait Pinc.6 , Set ’ check for button relace End If If Pinc.6 = 0 And Freezebit = 1 Then Print #1 , “:WFF3300” 'Freeze OFF Freezebit = 0 'set freezebit to freeze ON Bitwait Pinc.6 , Set ’ check for button relace End If 'If Pinc.7 = 0 Then ’ Print #1 , “:” 'not used yet ’ Bitwait Pinc.7 , Set 'End If Loop Close #1 End
Cleaning it up and/or using the code "#" button in the "post reply" editor would help us understand it better...
Sorry I have been very busy....' *********************************************************************************** ' * * ' * Title : VK-S274 & VK-S274R SERIES Hitachi Block Camera Controller * ' * Version : 1.1 Beta * ' * Last Updated : 02.12.2008 * ' * Target Device : ATMEGA8535 * ' * Author : Farmtech & Neptune769 * ' * Support : Try Skype Name : farmtech_dk or in MCS Bascom Forum * ' * Program code : BASCOM AVR * ' * Hardware req. : VK-S274 or VK-S274R SERIES Hitachi Block Camera * ' * Description : Control : Zoom - Focus & Iris Via Serialport on Camera * ' * Baud for camera : 4800.8.E.1 : Even Parity default for camera * ' * : 9600.8.N.1 but need setup in Camera (:WE05EF0) * ' * * ' * More Commands : See Datasheet lots of other stuff you can do. * ' * * ' * Datasheet : http://www.data-sheet.net/Vk-s454+ebook+pdf.html * ' * : http://ip.gliebetronics.com:800/hitachi/S274R_Comm_E11.pdf * ' * * ' * Copyright : None use it as you like * ' * * ' *********************************************************************************** $regfile = "m8535.dat" $crystal = 8000000 $hwstack = 40 $swstack = 30 $framesize = 60 Open "comd.2:4800,8,e,1" For Output As #1 ' 4800 bps , even Parity ; default for camera 'Config Ports for the 6 buttons n PortC we use buttons to GND Config Portc.0 = Input : Set Portc.0 'Zoom NEAR Button Config Portc.1 = Input : Set Portc.1 'Zoom FAR Button Config Portc.2 = Input : Set Portc.2 'Focus NEAR Button IN Config Portc.3 = Input : Set Portc.3 'Focus FAR Button OUT Config Portc.4 = Input : Set Portc.4 'Iris offset (average) + Button Config Portc.5 = Input : Set Portc.5 'Iris offset (average) - Button Config Portc.6 = Input : Set Portc.6 'Freeze ON / OFF Toggle Button 'Config Portc.7 = Input : Set Portc.7 'not used yet Button Dim I As Byte , Irish As Byte , Irisl As Byte , Irisavg As Byte , Freezebit As Byte 'Print Version() 'setup Camera Print #1 , ":WFCCB01" ' Switch the continuous digital zoom ON Waitms 10 Print #1 , ":WFDFC10" ' Zoom speed normal Waitms 10 Print #1 , ":WFCCB40" ' Switch the instant digital zoom ON Waitms 10 Print #1 , ":WFCBBA8" ' Auto focus ON allways (not on manual Focus) 'setup Iris offset (average) level Irisavg = &H40 ' Iris is normal hex 40 i hope Irish = 0 ' Bit set for Iris to HIGH Irisl = 0 ' Bit set for Iris to LOW Freezebit = 0 ' togglebit for freez images Wait 1 'The main program Do If Pinc.0 = 0 Then Print #1 , ":WFCBB99" ' zoom near Bitwait Pinc.0 , Set ' wait for button relace Print #1 , ":WFCBBFE" ' stop Print #1 , ":WFCBBA8" ' Auto focus on Waitms 300 ' wait for auto zoom to get focus End If If Pinc.1 = 0 Then Print #1 , ":WFCBB9B" ' zoom far Bitwait Pinc.1 , Set ' wait for button relace Print #1 , ":WFCBBFE" ' stop Print #1 , ":WFCBBA8" ' Auto focus on Waitms 300 ' wait for auto zoom to get focus End If If Pinc.2 = 0 Then Print #1 , ":WFCBBFE" ' Auto focus off Print #1 , ":WFCBBAA" ' focus near Bitwait Pinc.2 , Set ' wait for button relace Print #1 , ":WFCBBFE" ' stop End If If Pinc.3 = 0 Then Print #1 , ":WFCBBFE" ' Auto focus off Print #1 , ":WFCBBA9" ' focus far Bitwait Pinc.3 , Set ' wait for button relace Print #1 , ":WFCBBFE" ' stop End If 'Iris offset (average) level + Open If Pinc.4 = 0 And Irish = 0 Then 'if pinc.4 and irisbit high is 0 else skip Irisl = 0 ' reset to low bit I = Irisavg + 1 ' to start from known pos For I = Irisavg To 255 ' Irisavg to High 00 - FF Print #1 , ":WFD9E" ; Hex(i) 'Iris offset (average) send Irisavg = I ' put I count into Irisavg If I = 255 Then ' If MAX Iris then exit for Irish = 1 ' Set Iris bit TO high so it dont do the OPEN until you have closed it a bit Exit For End If If Pinc.4 = 1 Then Exit For ' check for button relace Next ' next i End If 'Iris offset (average) level - Close If Pinc.5 = 0 And Irisl = 0 Then ' if pinc.5 and irisbit low is 0 else skip Irish = 0 ' reset to high bit I = Irisavg ' to start from known pos For I = Irisavg To 0 Step -1 ' from Irisavg to MIN FF - 00 Print #1 , ":WFD9E" ; Hex(i) ' Iris offset (average) send Irisavg = I ' put I count into Irisavg If I = 0 Then ' If MIN Iris then exit for Irisl = 1 ' Set Iris bit TO low so it dont do the CLOSE until you have open it a bit Exit For End If If Pinc.5 = 1 Then Exit For ' check for button relace Next ' next i End If If Pinc.6 = 0 And Freezebit = 0 Then Print #1 , ":WFF3301" 'Freeze Field ON Freezebit = 1 'set freezebit to freeze OFF Bitwait Pinc.6 , Set ' check for button relace End If If Pinc.6 = 0 And Freezebit = 1 Then Print #1 , ":WFF3300" 'Freeze OFF Freezebit = 0 'set freezebit to freeze ON Bitwait Pinc.6 , Set ' check for button relace End If 'If Pinc.7 = 0 Then ' Print #1 , ":" 'not used yet ' Bitwait Pinc.7 , Set 'End If Loop Close #1 End
It is all still on one line.
It is extremely hard to read like that, try splitting it up, and we might have a chance to see what it is :)
A little googling turned up the below, which is probably a good place to start.
http://nemocam.com/media//DIR_13911/COM_914.pdf
BTW - Yes, that code is a variant of "BASIC"; I first I thought "QuickBASIC", but a little more reading makes me believe it is PicBasic or PBASIC (for the Parallax Basic Stamp). It shouldn't be too difficult to convert. But you need to post cleaner code!
So this is a link to the website where this code is referenced. http://nemocam.com/6294.html
Here is a direct link to the code http://nemocam.com/media/VK-S274_Ver_1$5B1$5D.1.bas
This was written in Bascom according to the author of the code, how should I clean it up? I know some java and none of what ever this language is written in :-[ I can't even tell where one command starts and one stops. I have downloaded bascom, but that did not help. The code looks no better then being posted here.
Not sure if this is any better?
Print Version() '
next i End If '
Print #1 , ":" '
not used yet '
This is as close as I can come to it (and without knowing BASCOM):
' *             http://ip.gliebetronics.com:800/hitachi/S274R_Comm_E11.pdf          *
$crystal = 8000000
$hwstack = 40
$swstack = 30
$framesize = 60
Open "comd.2:4800,8,e,1" For Output As #1 '4800 bps , even Parity ; default for camera
Print Version()
'setup Camera
Print #1 , ":WFCCB01" 'Switch the continuous digital zoom ON
Waitms 10
Print #1 , ":WFDFC10" 'Zoom speed normal
Waitms 10
Print #1 , ":WFCCB40" 'Switch the instant digital zoom ON
Waitms 10
Print #1 , ":WFCBBA8" 'Auto focus ON allways (not on manual Focus)
Irisavg = &H40 'Iris is normal hex 40 i hope
Irish = 0 'Bit set for Iris to HIGH
Irisl = 0 'Bit set for Iris to LOW
Wait 1
' The main program
Do
  If Pinc.0 = 0 Then
    Print #1 , ":WFCBB99" 'zoom near
    Bitwait Pinc.0 , Set 'wait for button relace
    Print #1 , ":WFCBBFE" 'stop
    Print #1 , ":WFCBBA8" 'Auto focus on
    Waitms 300 'wait for auto zoom to get focus
  End If
  If Pinc.1 = 0 Then
    Print #1 , ":WFCBB9B" 'zoom far
    Bitwait Pinc.1 , Set 'wait for button relace
  End If
  If Pinc.2 = 0 Then
    Print #1 , ":WFCBBFE" 'Auto focus off
    Print #1 , ":WFCBBAA" 'focus near
    Bitwait Pinc.2 , Set 'wait for button relace
  End If
  If Pinc.3 = 0 Then
    Print #1 , ":WFCBBA9" 'focus far
    Bitwait Pinc.3 , Set 'wait for button relace
  End If
    Irisl = 0 'reset to low bit
    I = Irisavg + 1 'to start from known pos
    For I = Irisavg To 255 'Irisavg to High 00 - FF
      Irisavg = I 'put I count into Irisavg
      If I = 255 Then 'If MAX Iris then exit for
        Irish = 1 'Set Iris bit TO high so it dont do the OPEN until you have closed it a bit
        Exit For
      End If
      If Pinc.4 = 1 Then Exit For 'check for button relace
    Next 'next i
  End If
  If Pinc.5 = 0 And Irisl = 0 Then 'if pinc.5 and irisbit low is 0 else skip
    Irish = 0 'reset to high bit
    I = Irisavg 'to start from known pos
    For I = Irisavg To 0 Step -1 'from Irisavg to MIN FF - 00
      If I = 0 Then 'If MIN Iris then exit for
        Irisl = 1 'Set Iris bit TO low so it dont do the CLOSE until you have open it a bit
        Exit For
      End If
      If Pinc.5 = 1 Then Exit For 'check for button relace
    Next 'next i
  End If
    Bitwait Pinc.6 , Set 'check for button relace
  End If
  End If
  If Pinc.7 = 0 Then
    'Print #1 , ":" 'not used yet
    'Bitwait Pinc.7 , Set
  End If
Loop
Close #1
End
Hope it helps!
