PWM to Serial converter
Hi all ,
I have camera Sony FBC , which accept commands as "Serial data RS232 " . In the other side I have Remote control Frsky which send command as " PWM " .
I want to use Arduino to receive "PWM" signal from the RC , And convert it to "Serial data RS232 "
For Example :
if ( PWM == 1100 ) low { Serial output = (8x 01 04 3E 02 FF); } else if ( PWM == 1800 ) high { Serial output = (8x 01 04 00 02 FF);
I hope the Idea is clear .
I appreciate any helpز
Regards . Jone
You can use the pulseIn() function to get the pulse width of the servo signal. Check the Reference.
For multiple channels received on a single line you need a RC receiver library, to split the received pulses again into multiple channels.
DrDiettrich: For multiple channels received on a single line you need a RC receiver library, to split the received pulses again into multiple channels.
Could you give me any link for the library ?
Is it essential to us the "Remote control Frsky" or would a wireless system more suited to the Arduino be a better alternative?
And if you do want to use the Frsky please post a link to its datasheet or user manual.
...R
I did some code will make the Idea clear more .
int PWM_Input_Pin = 3;
int pwm_value;
String zoomIn; // declare serial command for zoom in String zoomOut; // declare serial command for zoom out String StopZoom; // declare serial command for zoom stop
pinMode(PWM_Input_Pin , INPUT);
zoomIn = "8x 01 04 3E 02 FF"; zoomOut = "8x 01 04 00 02 FF"; StopZoom = "8x 01 01 00 02 FF";
pwm_value = pulseIn(PWM_Input_Pin ,HIGH);
pwm_value = map(pwm_value, 0, 1023, 1000, 2000); // I don't know if this right ??
if(Serial.available()== 0) { Serial.println(pwm_value);
if ( pwm_value == 1000) {
Serial.println(zoomIn);
}else if ( pwm_value == 1500){
Serial.println(StopZoom );
}else if ( pwm_value == 2000){
Serial.println(zoomOut); } }
delay(1000); }
the PWM is connected to Pin (3) the PWM range ( 1000 - 2000 ) 20ms
Any help to correcr the code . I am not sure about the map function.
Regards
I don't thinnk that you even need the map function. If you are measuring a servo signal (receiver output), pulseIn() will return a value between 1000 and 2000 microseconds (nominal.
What is the Serial.available doing?
