PWM trimming circuit
I am using PWM to control the speed of two servo motors. How can I have two PWM values, one for each motor?
feltsg:
you could try using analogWrite() selecting the pins controlled by different timers. I've listed the pins controlled by the 3 timers for a UNO.
  • Pins 5 and 6: controlled by Timer 0
  • Pins 9 and 10: controlled by timer 1
  • Pins 11 and 3: controlled by timer 2
Hope that helps
Servos or servomotors? I think you mean servos, in which case the Servo library is the obvious thing to use.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
