analogWrite(pin, value)
does the value have to be an integer between 0 and 255
can it be a float ie 0.01
can it be mapped to use more than 255 steps in duty cycle ?
Yes.
No.
No.
The value has to be 0..255. You can use timer1 that has a 16bits register. But you will have to write your own analogWrite function if I'm not wrong. Have a look at analogWrite code.
If you go to hardware/arduino/cores/arduino/wiring_analog.c you can see the source of "analogWrite"
ty
The output is 0-255, but you can start from any value you have if you scale it using the map() call:
x=map(value, fromLow, fromHigh, toLow, toHigh)
(http://www.arduino.cc/en/Reference/Map)
In your case, it would be
x=map(value, fromLow, fromHigh, 0, 255 );
However, this only works for integers - for float, you'd need to write your own, but since they provide the code there, it's pretty simple:
float map(float x, float in_min, float in_max, long out_min, long out_max)
return long ( (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min );
If you use float, be aware you may not be able to reach 255 because of floating point roundoff
@David Pankhurst: If the return type is float, returning a long is a bit limiting.
AWOL:
In his case, he wanted to limit to 0-255, so clamping to a long would work (even BYTE would be fine) - as well, he'd have to rename the function.
thanks for the ideas guys
so i could have instead of 0-255 > 0 - 10000
would that resolution get outputted to the output voltage ?
ie 0-5 V divided by 10000 ?
Gadget999:
In that case, the code is even simpler:
long value=8700; // for example
value=value*255/10000; 0-10000 -> 0-255
and the reverse
long value=237; // for example
value=value*10000/255; 0-255 -> 0-10000
