PWM using millis
For two days I’m tryng to change my Code from PWM to millis, no success
or there is a simple way that I’m missing
#include <LiquidCrystal.h>
#include "max6675.h"
#include "PID_v1R.h"  // similar to standard PID_v1, this custom library is required for full functionality
#include <avr/power.h>
#define CLK_DIV 8    // 8
// define 2 exceptions (temp and pid). TEMP_ALARM is fatal - program end.
#define TEMP_ALARM_MIN -10 // exceeds min temp limit [F]
#define TEMP_ALARM_MAX 300 // exceeds max temp limit [F]
/* PID limits should reflect actual physical capability. */
#define PID_MIN  0  // exceeds min PID limit
#define PID_MAX  255  // exceeds max PID limit
int TargetTemp = 0;
unsigned long currentTime = 0;
unsigned long startoffset;
#define TEMP_CORRECTION_OFFSET -0.0 // Thermocouple fudge factor [Fahrenheit]
// MAX6675 + Thermocouple convert Arduino Analog pins to power and communication.
// K-thermocouple only, 0-1024C range, 12-bit, 0.25C resolution, ~250K conversions/sec. max.
int thermoD0 =  15; // A1
int thermoCS =  16; // A2
int thermoCLK = 17; // A3
int vccPin =    18; // A4
int gndPin =    19; // A5
// PWM on 2 pins (+/-) using Timer 2 (16 bits)
int PWM_Pin_plus = 11;
int PWM_Pin_minus = 3;
// PID variables we connect to
double Setpoint = 100, Input = 20, Output, PV; // degrees Fahrenheit, Celsius or anything else
double PIDSAMPLETIME_MS = 1000 ;  // milliseconds
double Kp = 0.1, Ki = 0.3, Kd = 0.5, K = 1; // K is fudge factor for Output Gain or Thermal Resistance
unsigned long stepN;
// menu
int keypad_pin = A0;
int keypad_value = 0;
int keypad_value_old = 0;
char btn_push;
short mainMenuPage = 1;         // byte
short mainMenuPageOld = 1;      // byte
const int mainMenuTotal = 6;    // 5 + 1
typedef struct {                     // 5 steps in temperature profile
  char *desc;                        // description 16 char max.
  double Kp, Ki, Kd;                 // PID parameters
  double T1, T2, T3, T4, T5;         // T temperature
  unsigned long t1, t2, t3, t4, t5;  // t time [integer minutes]
} profile;
profile profiles[mainMenuTotal];
void t_PID(profile *r, double *T, unsigned long *t);
// create the objects
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
MAX6675 thermocouple(thermoCLK, thermoCS, thermoD0);
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);  // initialize the LCD library with the numbers of the interface pins
  clock_prescale_set(clock_div_8);
  lcd.begin(16, 2);     // LCD's number of columns and rows
  lcd.setCursor(0, 0);  // Print a message to the LCD
  lcd.print("PID Temp Control");
  // PID setup
  myPID.SetMode(AUTOMATIC);
  myPID.SetSampleTime(PIDSAMPLETIME_MS);
  myPID.SetOutputLimits(PID_MIN, PID_MAX);   // True PID heating and cooling. Should reflect actual physical limits
  // MAX6675 Temp. measurement setup
  pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);   // GND A5
  pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);  // VCC A4
  delay(1000 / CLK_DIV);
  // phase-correct PWM proportional output,  Timer 2 on pins 3, 11
  TCCR2A = _BV(COM2A1) | _BV(COM2B1) | _BV(WGM20);
  //TCCR2B = _BV(CS22);
  //TCCR2B = TCCR2B & B11111000 | B00000001;    // set timer 2 divisor to     1 for PWM frequency of 31372.55 Hz
  //TCCR2B = TCCR2B & B11111000 | B00000010;    // set timer 2 divisor to     8 for PWM frequency of  3921.16 Hz
  //TCCR2B = TCCR2B & B11111000 | B00000011;    // set timer 2 divisor to    32 for PWM frequency of   980.39 Hz
  //TCCR2B = TCCR2B & B11111000 | B00000100;    // set timer 2 divisor to    64 for PWM frequency of   490.20 Hz  <-- default
  //TCCR2B = TCCR2B & B11111000 | B00000101;    // set timer 2 divisor to   128 for PWM frequency of   245.10 Hz
  //TCCR2B = TCCR2B & B11111000 | B00000110;    // set timer 2 divisor to   256 for PWM frequency of   122.55 Hz
  TCCR2B = TCCR2B & B11111000 | B00000111;    // set timer 2 divisor to  1024 for PWM frequency of    30.64 Hz
  pinMode(PWM_Pin_plus,  OUTPUT);
  pinMode(PWM_Pin_minus, OUTPUT);
  // Serial
  Serial.begin(2400 * CLK_DIV);  // Change Serial Monitor tool datarate to 2400
  Serial.println("Arduino PID Temperature Control");
  // User Edit    "desc"    ,   Kp,  Ki,  Kd, T1,  T2,  T3,  T4,  T5,  t1,  t2,  t3,  t4,  t5 [t in integer minutes]
  profiles[0] = {"Default"  ,  0.1, 0.3, 0.5,  80,   0,   0,   0,   0, 72000, 0,   0,   0,   0};
  profiles[1] = {"Profile 1",  1.5, 0.3, 0.1, 130,  150, 120,  130,  150,  1,  1,  1,  1,  1};
  profiles[2] = {"Profile 2",  0.2, 0.3, 0.7, 160,   180,  200,  210,  0,   5,  3,  2,  1,   5};
  profiles[3] = {"Profile 3",  0.2, 0.4, 0.5, 20,   1,  30,  10,  40,   1,  50,  10,  60,   1};
  profiles[4] = {"Profile 4",  0.2, 0.4, 0.6, 20,   5,  30,   1,  40,   5,  50,   1,  60,   5};
  profiles[5] = {"Profile 5",  0.2, 0.4, 0.6, 30, 35,  30,  40,  30,   1,  1,   1,  1,   1};
  btn_push = ReadKeypad();
  WaitBtnRelease();
  MainMenuBtn();
  if (btn_push == 'S') // enter selected profile
    startoffset = millis();
    myPID.SetTunings(profiles[mainMenuPage].Kp, profiles[mainMenuPage].Ki, profiles[mainMenuPage].Kd);
    t_PID(&profiles[mainMenuPage], &profiles[mainMenuPage].T1, &profiles[mainMenuPage].t1 );
    t_PID(&profiles[mainMenuPage], &profiles[mainMenuPage].T2, &profiles[mainMenuPage].t2 );
    t_PID(&profiles[mainMenuPage], &profiles[mainMenuPage].T3, &profiles[mainMenuPage].t3 );
    t_PID(&profiles[mainMenuPage], &profiles[mainMenuPage].T4, &profiles[mainMenuPage].t4 );
    t_PID(&profiles[mainMenuPage], &profiles[mainMenuPage].T5, &profiles[mainMenuPage].t5 );
    PWM_OUT(0);   // turn off forcing functions
  MainMenuDisplay();
} // close loop()
void t_PID(profile *r, double *T, unsigned long *t) {
  unsigned long startTime = millis();
  unsigned long t_div = 60000;  // for accelerated testing, 1000ms/s * 60s/min = 60000 ms/min
  myPID.mySetpoint = T;
  TargetTemp = *T;
  while ((millis() - startTime) * CLK_DIV / t_div < *t) {
    PV = thermocouple.readCelsius() + TEMP_CORRECTION_OFFSET;  // Process Value (current temperature)
    Input = PV;  // uncomment to use for live operation
    if (Input <= TEMP_ALARM_MIN || Input >= TEMP_ALARM_MAX) {
      temp_alarm(Input);
    LCD_update(); SER_update();  // update the displays
    myPID.Compute();
    if (Output <= PID_MIN || Output >= PID_MAX) {
      pid_error();
    Input = Input + K * Output;
    PWM_OUT(K * Output);   // update the control outputs
    stepN++;
    delay(PIDSAMPLETIME_MS / CLK_DIV);
void LCD_update() {
  currentTime = (millis() - startoffset) / 125;
  lcd.clear();
  lcd.print(currentTime / 60); // AA Minutes
  lcd.print(":");
  lcd.print((currentTime % 60) / 10); // AA Seconds
  lcd.print((currentTime % 60) % 10);  // AA Seconds
  lcd.print(" I=");
  lcd.print(myPID.GetITerm(), 0);
  lcd.print(" D=");
  lcd.print(myPID.GetDTerm(), 0);
  lcd.setCursor(0, 1);
  lcd.print("T=");
  lcd.print(Input, 1);
  lcd.print("C");
  lcd.print(" ST=");
  lcd.print(TargetTemp, 1);
  delay(100);
void SER_update() {
  Serial.print("step\t sec.\t PV\t in\t out\t ITerm\t DTerm\t Target\t \n");
  Serial.print(stepN);
  Serial.print("\t");
  Serial.print(currentTime);  // seconds
  Serial.print("\t");
  Serial.print(PV);
  Serial.print("\t");
  Serial.print(Input);
  Serial.print("\t");
  Serial.print(Output);
  Serial.print("\t");
  Serial.print(myPID.GetITerm());
  Serial.print("\t");
  Serial.print(myPID.GetDTerm());
  Serial.println("\t");
  Serial.print(TargetTemp);
  Serial.println("\n");
I frgot to mention that PWM or millis is used for PID controll
You still need to tell us more. I can't make a link directly between PWM and millis()
What is the PWM for? How is it produced? Why does that need to be changed? What do you want to be able to do?
What is the project you are trying to create? - so we can see your questions in their context.
...R
Sorry, as usually I think that everyone knows
what I mean :slight_smile: :slight_smile:
I’m using Uno and SSR to control a Heater using PID library.
I have one Thermocouple attached to measure temperature.
I’v programed Profiles for SetPoints.
novio8
The first thing I see there is a while loop.
Replace while with if, then you won't be blocking.
The whole point of using millis() rather than delay() is to avoid blocking, so that you can do other stuff too.
Think like this: "if its time to do something, then do it" Don't think like this "I need to wait X milliseconds before I do the next thing"
novio8: I'm using Uno and SSR to control a Heater using PID library.
I still don't see the connection that is in your mind between PWM and millis() - to my mind they are for two very different purposes.
And I agree with what @MarkT has said. The demo Several Things at a Time illustrates the use of millis() to manage timing without blocking. It may help with understanding the technique.
Have a look at Using millis() for timing. A beginners guide if you need more explanation.
...R
I have changed PWM frequency to 30.64 Hz and divided Clock #define CLK_DIV 8 // 8 so that I have around 4 HZ PWM, to avoid SSR Zero crossing problems. This way my Code works OK, I would like to add a DC Motor Control, for this purpuse PWM Frequency is now too Low, so I have to return Clock to Default Value and use millis to generate PWM Signal
Have a look here: https://playground.arduino.cc/Code/PIDLibraryRelayOutputExample
That being said, whenever I read about someone trying to do temperature control with a PID, I always scratch my head and wonder why. What's wrong with good old bang-bang control and a degree or so of Hysteresis? The thermostat in just about every HVAC system in every house in the world works this way.
novio8: so that I have around 4 HZ PWM, to avoid SSR Zero crossing problems. This way my Code works OK, I would like to add a DC Motor Control, for this purpuse PWM Frequency is now too Low, so I have to return Clock to Default Value and use millis to generate PWM Signal
Finally, we have an explanation. It could easily have been included in your Original Post.
Have a look at how millis() is used to flash LED in Several Things at a Time.
...R
novio8: I have changed PWM frequency to 30.64 Hz and divided Clock #define CLK_DIV 8 // 8 so that I have around 4 HZ PWM, to avoid SSR Zero crossing problems. This way my Code works OK, I would like to add a DC Motor Control, for this purpuse PWM Frequency is now too Low, so I have to return Clock to Default Value and use millis to generate PWM Signal
There are 3 hardware timers on the UNO. (You didn't say which Arduino you have.) You only changed timer 2. Use PWM pins which are on different timers for your motor.
Note the timer 0 frequency should not be changed as it drives millis().
My Replies
gfvalvo you are right, now I wonder too. Maybe it just sounds so sofisticated...
Robin2 you are right too, I looked at Several Things at a Time, But it seems I just can't impement it correctly in my case. So I'm asking for help.
MorganS, I'M using Arduino Uno. I frgot about three Timers, but don't frget that I divided Clock #define CLK_DIV 8 // 8
novio8: Robin2 you are right too, I looked at Several Things at a Time, But it seems I just can't impement it correctly in my case. So I'm asking for help.
I will try to help if you post the program that represents your best attempt and tell us in detail what it does and what you want it to do that is different.
...R
novio8:
gfvalvo you are right, now I wonder too. Maybe it just sounds so sofisticated…
Remember that “Better” is the enemy of “Good Enough”.
For two days I'm trying to change my Code from PWM to millis, no success or there is a simple way that I'm missing
@gfvalvo tried to point you at the relayoutput example from the library. Did you look at it. What does it not do, in regards to slower operation of the SSR, that you want.
PID RelayOutput Example Same as basic example, except that this time, the output is going to a digital pin which (we presume) is controlling a relay. The pid is designed to output an analog value, but the relay can only be On/Off.
To connect them together we use "time proportioning control" Tt's essentially a really slow version of PWM. First we decide on a window size (5000mS say.) We then set the pid to adjust its output between 0 and that window size. Lastly, we add some logic that translates the PID output into "Relay On Time" with the remainder of the window being "Relay Off Time"
cattledog:
Cattledog, U looked at that example, but I can’t figure out how to change my Code. I generate
PWM Output to SSR as bellow
  TargetTemp = *T;
      temp_alarm(Input);
    myPID.Compute();
      pid_error();
    stepN++;
I recommend that you back up a bit and start from the basic pid library relay example.
The key to relay control is that the output limits are changed from the typical 0-255 for the case where the output is called with analogWrite(pwmPin, output).
Instead, you use output limits like 0-5000 for a 5 second slow pwm cycle time. In the example this is called the Window Size.
Then the output value from pid.compute() will represent some ON time in that interval. The actual code in the example which sets whether the output is on or off is this
if (millis() - windowStartTime > WindowSize)
  { //time to shift the Relay Window
    windowStartTime += WindowSize;
  if (Output < millis() - windowStartTime) digitalWrite(RELAY_PIN, HIGH);
  else digitalWrite(RELAY_PIN, LOW);
There are many ways code this, and it is basically “blink without delay” with different on/off times where the pid library is setting the on/off times.
Please explain what you can not do with the standard library. Where is the source code for the “v1R” library you are referencing?
cattledog,
I did exatly what you suggested, I started again and Relay example is a good way to go, but It will take me a while to rewrite the Code
To All who responded Thank you
