I want PWM variable volatge increase from 0-5V to 0-30V .so i use lm317T and op amp lm741, but it will increases voltage level to 0-11V .how could it possible to increase it to 30V ....i am sorry, in circuit diagram attached. Vin of lm317T is 12V not 60V
The LM317T won't do what you need. Better to go for the currently favoured usual route .... use a suitable Logic Level n-channel mosfet to switch a 30V dc supply...... with your 0 and 5V level pwm signal at the gate input.
It sounds as if you are incorrectly assuming that a electronic component like a voltage regulator does what you incorrectly think it is meant to do. The LM317T is a voltage regulator. This won't do what you think it does.
Why? It is PWM so that means it is only zero or five volts nothing in between. So if you want a 0 to 30V PWM all you need is a 30V supply and transistor and two resistors.
