I'm trying to drive a voice coil with a low frequency (around 100Hz) and I need to set the "on" time and volume of the drive pulse independently. I am using a higher frequency PWM to control volume. I turn analogWrite on and off to set the "on" time, and adjust duty cycle to change the volume. The problem is that I can hear a glitch or buzz occuring twice a second with the code as shown. If I use delay instead of delayMicroseconds the glitches are more erratic but still present. Using a "for" loop instead of delay gave a different pattern of noise, but still getting the noise. Any suggestions?
PWM volume control
Low frequency signal turns on high frequency PWM
int Outpin = 9; //TP4
long ontime = 5; //sets the ontime to half a cycle at 100Hz
int DutyCycle = 25; //duty cycle of 25/255 for testing.
pinMode(Outpin, OUTPUT);
TCCR1B = TCCR1B & 0b11111000|0b1;
analogWrite(Outpin,DutyCycle);
delay(ontime);
digitalWrite(Outpin, LOW);
delay(ontime); //"off" time equal to "on" time for testing
It is rather a dubious thing you are trying to do.
Not surprising because there are interrupts running to keep the millis() timer updated and this is going asynchronously with your code.
Not a lot you can do about it if you program it that way. You can get an audio output using interrupts though. I am not sure what the "on time" is and how the PWM amplitude modulates it.
Can you draw a circuit to show what sort of filtering you have on the PWM output.
Yippee, problem solved. Because the PWM signal was being turned on by an asynchronous signal (whatever the loop time happens to be), sometimes the counter value would be such that the first pulse would be extra long. By resetting Timer1 before I turn on PWM with analogWrite, I never get the extra long first pulse.
PWM volume control
TCCR1B = TCCR1B & 0b11111000|0b1; //raising the PWM frequency to about 32kHz
TCNT1=0; //Resets the counter in Timer1 to zero each time
delay(ontime);
