PWM with Melody
I'am designing circuits for my flashlight. And to keep the story as short as posible. I want to use 5 out of 6 PWM pins, and also use a piezo to make sounds.
When I read the tone function reference, you see that PWM on pin 3 and 11 are interfered with the tone function.
I need to use pin 11 for PWM. But it does not have the changer the PWM level during a sound. Just be adjustable with no sound is enough.
I tried some simple code to test it, and with the simple code it didn't work. It made weard sounds, and/or the led didn't work, but the same code did work on pin 10 for example.
But, I also found a simple melody code, and added some code for the led and a potentiometer for brightness adjust, and it did work on pin 11. After the melody played, I could change the led brightness, the PWM did not change during the sound on pin 8.
So I'am confused if I can use pin 11 for simple PWM of not.
This code does NOT work with a melody and PWM on pin 11...
#include "pitches.h"
int pot = 0;
int led = 11;
int i = 0;
int potval = 0;
int melody[] = {
NOTE_C4, NOTE_G3,NOTE_G3, NOTE_A3, NOTE_G3,0, NOTE_B3, NOTE_C4};
int noteDurations[] = {
4, 8, 8, 4,4,4,4,4 };
pinMode (led, OUTPUT);
pinMode (pot, INPUT);
for (int thisNote = 0; thisNote < 8; thisNote++) {
// to calculate the note duration, take one second
// divided by the note type.
//e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
int noteDuration = 1000/noteDurations[thisNote];
tone(8, melody[thisNote],noteDuration);
// to distinguish the notes, set a minimum time between them.
// the note's duration + 30% seems to work well:
int pauseBetweenNotes = noteDuration * 1.30;
delay(pauseBetweenNotes);
// potentiometer and led PWM on pin 11 code...
potval = analogRead (pot);
i = map (potval, 0, 1023, 0, 255);
analogWrite (led, i);
This code does WORK on pin11 with PWM...
int speakerPin = 8;
int pot = 0;
int led = 11;
int i = 0;
int potval = 0;
int length = 22; // the number of notes
char notes[] = "ccggaagffeeddcffeeddc "; // a space represents a rest
int beats[] = { 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 1,1,1,1,1,1,1,1 };
int tempo = 70;
void playTone(int tone, int duration) {
for (long i = 0; i < duration * 1000L; i += tone * 2) {
digitalWrite(speakerPin, HIGH);
delayMicroseconds(tone);
digitalWrite(speakerPin, LOW);
void playNote(char note, int duration) {
char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' };
int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956 };
// play the tone corresponding to the note name
for (int i = 0; i < 8; i++) {
if (names == note) {
_ playTone(tones*, duration);_
_
}_
_
}_
_
}_
_
pinMode(speakerPin, OUTPUT);_
_
pinMode (led, OUTPUT);_
_
pinMode (pot, INPUT);_
_
Serial.begin(9600);_
_
}_
_
for (int i = 0; i < length; i++) {_
_ if (notes == ' ') {_
delay(beats _ tempo); // rest_
* } else {*
playNote(notes, beats * tempo);
* // pause between notes*
* delay(tempo / 2);*
* // led and potentiometer code...*
I'am no expert on arduino code, but for now I just need to know for my circuit design if I can use pin11 PWM or not.
As I sad, the PWM on pin11 do not need to change during a tone, but the PWM sould be stable during a tone, just like the code above that's working. But I don't understand why one code can't work with pin11 during a tone, and the other can, why?
I also want no delay functions in the final code, thats a problem?
I hope someone can clearify this for me.
Thanks for your time.
I think I figured it out.
You can make melody's by manualy making the frequency by using microseconds delay's between up and down time.
And you can use the chip function for making tones.
Manually is ok for some apps, but you can't run code on the same time. The sounds are distorted when more code is added. So for a smooth tone, it needs to loop only the up and down code.
This is not handy for my app. multiple codes are running on the same time.
So I will use the tone function, and loose one PWM I wanted to use.
I also read something about differences between PWM pins.
Some work twice as fast as others. But the faster ones share timing function or something?
Is it smart to use the faster PWM pins for the main leds on my flashlight? Or because it's shared by timer functions it can go bad somehow?
