Trying to set the Analog pins to digital outputs or just outputs instead of inputs using Pyfirmata but I am having trouble and I have not been able to find a good resource online that worked. Does anyone have any luck with this?
What happens if you simply treat them as if they were digital pins as, after all, that is what they are ?
It doesn't output anything from what I can tell.
I know very little about Pyfirmata but how do you set an analogue pin to be a digital input ? Is there a special syntax for doing it compared to setting a purely digital pin to input ? For instance, do you refer to the pins by number or their A* name ?
