I am designing a project that uses a raspberry pi to control & collect Data from a Mega 2560 clone. (security system) & initially I was going to run the 2560 as a modbus/rtu client but the project was becoming too complex so I changed direction to use standard Firmatta on the arduino & Pyfirmatta on the PI. For the moment I am using a HP netbook running Linux mint for proof of concept as pyfirmatta will need to be compiled for the R-PI.
The issue I have run into is that on the Mega 2560 I am intending to use. (Clone with the CH340G USB chip) I cannot read the value of the digital inputs. They always come back as (None) I wasted almost three evenings on this before trying another board (genuine) that had been junked as the I2c port was fried. & it worked, with all of the code examples I had tried on the old board & failed.
Interestingly the firmatta test program works perfectly on both boards. so its an issue with Pyfirmatta Probably timing.
Has anyone any idea what could be causing the issue.
