Pymata express serial communication with arduino uno is extremely slow
As a part of a project,i was trying to control stepper motor at high speed using arduino uno and pyfirmata express library. the code i tried given below.
'''program for controlling stepper motor at high speed(rpm)'''
from pymata_express import pymata_express
import asyncio
import pause #to add accurate delay between each stepper motor pulse
pulse=11#arduino pin to provide step
direction=12#arduino pin to provide direction of rotation
loop = asyncio.get_event_loop()
board=pymata_express.PymataExpress('COM6')
async def move():
    await board.set_pin_mode_digital_output(pulse)
    await board.set_pin_mode_digital_output(direction)
    delay_time=0.00001#delay of 10 microseconds for each step
    await board.digital_write(direction,1)
    dt=datetime.datetime.now()
    ts=dt.timestamp()
    for i in range(int(10000)):
	await board.digital_write(pulse,1)
	pause.until(ts+i*delay_time)#pause to provide delay time
	await board.digital_write(pulse,0)
loop.run_until_complete(move())
The expected finishing time of loop is 0.2 seconds,but it took more than 5 seconds to complete.I think it is because of waiting for digital_write is takes longer time. Is there any solution for my problem? Any ideas?
THANKS!
-THAHIR
Please post the Arduino sketch that you are communicating with
Does it contain any blocking code ?
I used firmata express example code provided in the arduino. i didnt change anything.
For those of us that don't have the library installed please post it here
Firmata express library contains a lot of examples. Please insert the exact code in the forum, using code tags.
https://github.com/MrYsLab/FirmataExpress/blob/master/examples/FirmataExpress/FirmataExpress.ino
Still not posted here. Why make it more difficult to provide help than it needs to be ?
sorry, the program is very large, link to the example code is given above. Please check that link.. :slightly_smiling_face:
It only took me about 5 mouse clicks to post the code as you could not be bothered
  Firmata is a generic protocol for communicating with microcontrollers
  from software on a host computer. It is intended to work with
  any host computer software package.
  To download a host software package, please click on the following link
  to open the list of Firmata client libraries in your default browser.
  https://github.com/firmata/arduino#firmata-client-libraries
  Copyright (C) 2006-2008 Hans-Christoph Steiner.  All rights reserved.
  Copyright (C) 2010-2011 Paul Stoffregen.  All rights reserved.
  Copyright (C) 2009 Shigeru Kobayashi.  All rights reserved.
  Copyright (C) 2009-2016 Jeff Hoefs.  All rights reserved.
  Copyright (C) 2018-2021 Alan Yorinks. All Rights Reserved.
  DHT Humidity/Temperature Sensor Support based on work provided by Martyn Wheeler
  Based on the DHTNew library - https://github.com/RobTillaart/DHTNew
  This program is free software; you can redistribute it and/or
  modify it under the terms of the GNU AFFERO GENERAL PUBLIC LICENSE
  Version 3 as published by the Free Software Foundation; either
  or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  General Public License for more details.
  You should have received a copy of the GNU AFFERO GENERAL PUBLIC LICENSE
  along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
  See file LICENSE.txt for further information on licensing terms.
  Last updated May 25, 2021
#include <Servo.h>
#include <Wire.h>
#include <FirmataExpress.h>
#include <Ultrasonic.h>
#include <Stepper.h>
#include <DHTStable.h>
#if defined(__AVR__)
#include <avr/wdt.h>
#endif
#define ARDUINO_INSTANCE_ID         1
#define I2C_WRITE                   B00000000
#define I2C_READ                    B00001000
#define I2C_READ_CONTINUOUSLY       B00010000
#define I2C_STOP_READING            B00011000
#define I2C_READ_WRITE_MODE_MASK    B00011000
#define I2C_10BIT_ADDRESS_MODE_MASK B00100000
#define I2C_END_TX_MASK             B01000000
#define I2C_STOP_TX                 1
#define I2C_RESTART_TX              0
#define I2C_MAX_QUERIES             8
#define I2C_REGISTER_NOT_SPECIFIED  -1
// the minimum interval for sampling analog input
#define MINIMUM_SAMPLING_INTERVAL 1
#define INTER_PING_INTERVAL 40 // 40 ms.
extern void printData(char *id, long data);
// SYSEX command sub specifiers
#define TONE_TONE 0
#define TONE_NO_TONE 1
#endif
#define STEPPER_CONFIGURE 0
#define STEPPER_STEP 1
#define STEPPER_LIBRARY_VERSION 2
// DHT Sensor definitions
#define DHT_INTER_PING_INTERVAL 2200 // 2000 ms.
#define DHTLIB_OK                0
   GLOBAL VARIABLES
#ifdef FIRMATA_SERIAL_FEATURE
SerialFirmata serialFeature;
#endif
/* analog inputs */
int analogInputsToReport = 0; // bitwise array to store pin reporting
/* digital input ports */
byte reportPINs[TOTAL_PORTS];       // 1 = report this port, 0 = silence
byte previousPINs[TOTAL_PORTS];     // previous 8 bits sent
/* pins configuration */
byte portConfigInputs[TOTAL_PORTS]; // each bit: 1 = pin in INPUT, 0 = anything else
/* timer variables */
unsigned long currentMillis;        // store the current value from millis()
unsigned long previousMillis;       // for comparison with currentMillis
unsigned int samplingInterval = 19; // how often to run the main loop (in ms)
unsigned long previousKeepAliveMillis = 0;
unsigned int keepAliveInterval = 0;
#endif
/* i2c data */
struct i2c_device_info {
    byte addr;
    int reg;
    byte bytes;
    byte stopTX;
/* for i2c read continuous more */
i2c_device_info query[I2C_MAX_QUERIES];
byte i2cRxData[64];
boolean isI2CEnabled = false;
signed char queryIndex = -1;
// default delay time between i2c read request and Wire.requestFrom()
unsigned int i2cReadDelayTime = 0;
Servo servos[MAX_SERVOS];
byte servoPinMap[TOTAL_PINS];
byte detachedServos[MAX_SERVOS];
byte detachedServoCount = 0;
byte servoCount = 0;
boolean isResetting = false;
// Forward declare a few functions to avoid compiler errors with older versions
// of the Arduino IDE.
void setPinModeCallback(byte, int);
void reportAnalogCallback(byte analogPin, int value);
void sysexCallback(byte, byte, byte *);
/* utility functions */
void wireWrite(byte data) {
#if ARDUINO >= 100
    Wire.write((byte)data);
#else
    Wire.send(data);
#endif
byte wireRead(void) {
#if ARDUINO >= 100
    return Wire.read();
#else
    return Wire.receive();
#endif
// Ping variables
int numLoops = 0;
int pingLoopCounter = 0;
int numActiveSonars = 0; // number of sonars attached
uint8_t sonarPinNumbers[MAX_SONARS];
int nextSonar = 0; // index into sonars[] for next device
// array to hold up to 6 instances of sonar devices
Ultrasonic *sonars[MAX_SONARS];
uint8_t sonarTriggerPin;
uint8_t sonarEchoPin;
uint8_t currentSonar = 0;            // Keeps track of which sensor is active.
uint8_t pingInterval = 33;  // Milliseconds between sensor pings (29ms is about the min to avoid
// cross- sensor echo).
byte sonarMSB, sonarLSB;
// Stepper Motor
Stepper *stepper = NULL;
// DHT sensors
int numActiveDHTs = 0; // number of DHTs attached
uint8_t DHT_PinNumbers[MAX_DHTS];
uint8_t DHT_WakeUpDelay[MAX_DHTS];
uint8_t DHT_TYPE[MAX_DHTS];
DHTStable DHT; // instance of dhtstable
uint8_t nextDHT = 0; // index into dht[] for next device
uint8_t currentDHT = 0;            // Keeps track of which sensor is active.
int dhtNumLoops = 0;
int dhtLoopCounter = 0;
uint8_t dht_value[4];  // buffer to receive data
   FUNCTIONS
void attachServo(byte pin, int minPulse, int maxPulse) {
    if (servoCount < MAX_SERVOS) {
        // reuse indexes of detached servos until all have been reallocated
        if (detachedServoCount > 0) {
            servoPinMap[pin] = detachedServos[detachedServoCount - 1];
            if (detachedServoCount > 0) detachedServoCount--;
            servoPinMap[pin] = servoCount;
            servoCount++;
        if (minPulse > 0 && maxPulse > 0) {
            servos[servoPinMap[pin]].attach(PIN_TO_DIGITAL(pin), minPulse, maxPulse);
            servos[servoPinMap[pin]].attach(PIN_TO_DIGITAL(pin));
        Firmata.sendString("Max servos attached");
void detachServo(byte pin) {
    servos[servoPinMap[pin]].detach();
    // if we're detaching the last servo, decrement the count
    // otherwise store the index of the detached servo
    if (servoPinMap[pin] == servoCount && servoCount > 0) {
        servoCount--;
    } else if (servoCount > 0) {
        // keep track of detached servos because we want to reuse their indexes
        // before incrementing the count of attached servos
        detachedServoCount++;
        detachedServos[detachedServoCount - 1] = servoPinMap[pin];
    servoPinMap[pin] = 255;
void enableI2CPins() {
    byte i;
    // is there a faster way to do this? would probaby require importing
    // Arduino.h to get SCL and SDA pins
    for (i = 0; i < TOTAL_PINS; i++) {
        if (IS_PIN_I2C(i)) {
            // mark pins as i2c so they are ignore in non i2c data requests
            setPinModeCallback(i, PIN_MODE_I2C);
    isI2CEnabled = true;
    Wire.begin();
/* disable the i2c pins so they can be used for other functions */
void disableI2CPins() {
    // disable read continuous mode for all devices
    queryIndex = -1;
void readAndReportData(byte address, int theRegister, byte numBytes, byte stopTX) {
    // allow I2C requests that don't require a register read
    // for example, some devices using an interrupt pin to signify new data available
    // do not always require the register read so upon interrupt you call Wire.requestFrom()
    if (theRegister != I2C_REGISTER_NOT_SPECIFIED) {
        Wire.beginTransmission(address);
        wireWrite((byte) theRegister);
        Wire.endTransmission(stopTX); // default = true
        // do not set a value of 0
        if (i2cReadDelayTime > 0) {
            // delay is necessary for some devices such as WiiNunchuck
            delayMicroseconds(i2cReadDelayTime);
        theRegister = 0;  // fill the register with a dummy value
    Wire.requestFrom(address, numBytes);  // all bytes are returned in requestFrom
    // check to be sure correct number of bytes were returned by slave
    if (numBytes < Wire.available()) {
        Firmata.sendString("I2C: Too many bytes received");
    } else if (numBytes > Wire.available()) {
        Firmata.sendString("I2C: Too few bytes received");
    i2cRxData[0] = address;
    i2cRxData[1] = theRegister;
    for (int i = 0; i < numBytes && Wire.available(); i++) {
        i2cRxData[2 + i] = wireRead();
    // send slave address, register and received bytes
    Firmata.sendSysex(SYSEX_I2C_REPLY, numBytes + 2, i2cRxData);
void outputPort(byte portNumber, byte portValue, byte forceSend) {
    // pins not configured as INPUT are cleared to zeros
    portValue = portValue & portConfigInputs[portNumber];
    // only send if the value is different than previously sent
    if (forceSend || previousPINs[portNumber] != portValue) {
        Firmata.sendDigitalPort(portNumber, portValue);
        previousPINs[portNumber] = portValue;
   check all the active digital inputs for change of state, then add any events
   to the Serial output queue using Serial.print() */
void checkDigitalInputs(void) {
    /* Using non-looping code allows constants to be given to readPort().
       The compiler will apply substantial optimizations if the inputs
       to readPort() are compile-time constants. */
    if (TOTAL_PORTS > 0 && reportPINs[0]) outputPort(0, readPort(0, portConfigInputs[0]), false);
    if (TOTAL_PORTS > 1 && reportPINs[1]) outputPort(1, readPort(1, portConfigInputs[1]), false);
    if (TOTAL_PORTS > 2 && reportPINs[2]) outputPort(2, readPort(2, portConfigInputs[2]), false);
    if (TOTAL_PORTS > 3 && reportPINs[3]) outputPort(3, readPort(3, portConfigInputs[3]), false);
    if (TOTAL_PORTS > 4 && reportPINs[4]) outputPort(4, readPort(4, portConfigInputs[4]), false);
    if (TOTAL_PORTS > 5 && reportPINs[5]) outputPort(5, readPort(5, portConfigInputs[5]), false);
    if (TOTAL_PORTS > 6 && reportPINs[6]) outputPort(6, readPort(6, portConfigInputs[6]), false);
    if (TOTAL_PORTS > 7 && reportPINs[7]) outputPort(7, readPort(7, portConfigInputs[7]), false);
    if (TOTAL_PORTS > 8 && reportPINs[8]) outputPort(8, readPort(8, portConfigInputs[8]), false);
    if (TOTAL_PORTS > 9 && reportPINs[9]) outputPort(9, readPort(9, portConfigInputs[9]), false);
    if (TOTAL_PORTS > 10 && reportPINs[10]) outputPort(10, readPort(10, portConfigInputs[10]), false);
    if (TOTAL_PORTS > 11 && reportPINs[11]) outputPort(11, readPort(11, portConfigInputs[11]), false);
    if (TOTAL_PORTS > 12 && reportPINs[12]) outputPort(12, readPort(12, portConfigInputs[12]), false);
    if (TOTAL_PORTS > 13 && reportPINs[13]) outputPort(13, readPort(13, portConfigInputs[13]), false);
    if (TOTAL_PORTS > 14 && reportPINs[14]) outputPort(14, readPort(14, portConfigInputs[14]), false);
    if (TOTAL_PORTS > 15 && reportPINs[15]) outputPort(15, readPort(15, portConfigInputs[15]), false);
/* sets the pin mode to the correct state and sets the relevant bits in the
   two bit-arrays that track Digital I/O and PWM status
void setPinModeCallback(byte pin, int mode) {
    if (Firmata.getPinMode(pin) == PIN_MODE_IGNORE)
        return;
    if (Firmata.getPinMode(pin) == PIN_MODE_I2C && isI2CEnabled && mode != PIN_MODE_I2C) {
        // disable i2c so pins can be used for other functions
        // the following if statements should reconfigure the pins properly
        disableI2CPins();
    if (IS_PIN_DIGITAL(pin) && mode != PIN_MODE_SERVO) {
        if (servoPinMap[pin] < MAX_SERVOS && servos[servoPinMap[pin]].attached()) {
            detachServo(pin);
    if (IS_PIN_ANALOG(pin)) {
        reportAnalogCallback(PIN_TO_ANALOG(pin), mode == PIN_MODE_ANALOG ? 1 : 0); // turn on/off reporting
    if (IS_PIN_DIGITAL(pin)) {
        if (mode == INPUT || mode == PIN_MODE_PULLUP) {
            portConfigInputs[pin / 8] |= (1 << (pin & 7));
            portConfigInputs[pin / 8] &= ~(1 << (pin & 7));
    Firmata.setPinState(pin, 0);
    switch (mode) {
        case PIN_MODE_ANALOG:
                    pinMode(PIN_TO_DIGITAL(pin), INPUT);    // disable output driver
#if ARDUINO <= 100
                    // deprecated since Arduino 1.0.1 - TODO: drop support in Firmata 2.6
                    digitalWrite(PIN_TO_DIGITAL(pin), LOW); // disable internal pull-ups
#endif
                Firmata.setPinMode(pin, PIN_MODE_ANALOG);
        case INPUT:
#if ARDUINO <= 100
#endif
                Firmata.setPinMode(pin, INPUT);
        case PIN_MODE_PULLUP:
                pinMode(PIN_TO_DIGITAL(pin), INPUT_PULLUP);
                Firmata.setPinMode(pin, PIN_MODE_PULLUP);
                Firmata.setPinState(pin, 1);
        case OUTPUT:
                if (Firmata.getPinMode(pin) == PIN_MODE_PWM) {
                    // Disable PWM if pin mode was previously set to PWM.
                pinMode(PIN_TO_DIGITAL(pin), OUTPUT);
                Firmata.setPinMode(pin, OUTPUT);
        case PIN_MODE_PWM:
            if (IS_PIN_PWM(pin)) {
                pinMode(PIN_TO_PWM(pin), OUTPUT);
                analogWrite(PIN_TO_PWM(pin), 0);
                Firmata.setPinMode(pin, PIN_MODE_PWM);
        case PIN_MODE_SERVO:
                Firmata.setPinMode(pin, PIN_MODE_SERVO);
                if (servoPinMap[pin] == 255 || !servos[servoPinMap[pin]].attached()) {
                    // pass -1 for min and max pulse values to use default values set
                    // by Servo library
                    attachServo(pin, -1, -1);
        case PIN_MODE_I2C:
            if (IS_PIN_I2C(pin)) {
                // mark the pin as i2c
                // the user must call I2C_CONFIG to enable I2C for a device
                Firmata.setPinMode(pin, PIN_MODE_I2C);
        case PIN_MODE_SERIAL:
            serialFeature.handlePinMode(pin, PIN_MODE_SERIAL);
#endif
            case PIN_MODE_TONE:
      Firmata.setPinMode(pin, PIN_MODE_TONE);
      break ;
#endif
        case PIN_MODE_SONAR:
            Firmata.setPinMode(pin, PIN_MODE_SONAR);
        case PIN_MODE_DHT:
            Firmata.setPinMode(pin, PIN_MODE_DHT);
        case PIN_MODE_STEPPER:
            Firmata.setPinMode(pin, PIN_MODE_STEPPER);
        default:
            Firmata.sendString("Unknown pin mode"); // TODO: put error msgs in EEPROM
    // TODO: save status to EEPROM here, if changed
   Sets the value of an individual pin. Useful if you want to set a pin value but
   are not tracking the digital port state.
   Can only be used on pins configured as OUTPUT.
   Cannot be used to enable pull-ups on Digital INPUT pins.
void setPinValueCallback(byte pin, int value) {
    if (pin < TOTAL_PINS && IS_PIN_DIGITAL(pin)) {
        if (Firmata.getPinMode(pin) == OUTPUT) {
            Firmata.setPinState(pin, value);
            digitalWrite(PIN_TO_DIGITAL(pin), value);
void analogWriteCallback(byte pin, int value) {
    if (pin < TOTAL_PINS) {
        switch (Firmata.getPinMode(pin)) {
                    servos[servoPinMap[pin]].write(value);
            case PIN_MODE_PWM:
                    analogWrite(PIN_TO_PWM(pin), value);
void digitalWriteCallback(byte port, int value) {
    byte pin, lastPin, pinValue, mask = 1, pinWriteMask = 0;
    if (port < TOTAL_PORTS) {
        // create a mask of the pins on this port that are writable.
        lastPin = port * 8 + 8;
        if (lastPin > TOTAL_PINS) lastPin = TOTAL_PINS;
        for (pin = port * 8; pin < lastPin; pin++) {
            // do not disturb non-digital pins (eg, Rx & Tx)
                // do not touch pins in PWM, ANALOG, SERVO or other modes
                if (Firmata.getPinMode(pin) == OUTPUT || Firmata.getPinMode(pin) == INPUT) {
                    pinValue = ((byte) value & mask) ? 1 : 0;
                        pinWriteMask |= mask;
                    } else if (Firmata.getPinMode(pin) == INPUT && pinValue == 1 && Firmata.getPinState(pin) != 1) {
                        // only handle INPUT here for backwards compatibility
#if ARDUINO > 100
                        pinMode(pin, INPUT_PULLUP);
#else
                        // only write to the INPUT pin to enable pullups if Arduino v1.0.0 or earlier
#endif
                    Firmata.setPinState(pin, pinValue);
            mask = mask << 1;
        writePort(port, (byte) value, pinWriteMask);
/* sets bits in a bit array (int) to toggle the reporting of the analogIns
//void FirmataClass::setAnalogPinReporting(byte pin, byte state) {
void reportAnalogCallback(byte analogPin, int value) {
    if (analogPin < TOTAL_ANALOG_PINS) {
        if (value == 0) {
            analogInputsToReport = analogInputsToReport & ~(1 << analogPin);
            analogInputsToReport = analogInputsToReport | (1 << analogPin);
            // prevent during system reset or all analog pin values will be reported
            // which may report noise for unconnected analog pins
            if (!isResetting) {
                // Send pin value immediately. This is helpful when connected via
                // ethernet, wi-fi or bluetooth so pin states can be known upon
                // reconnecting.
                Firmata.sendAnalog(analogPin, analogRead(analogPin));
void reportDigitalCallback(byte port, int value) {
        reportPINs[port] = (byte) value;
        // Send port value immediately. This is helpful when connected via
        // reconnecting.
        if (value) outputPort(port, readPort(port, portConfigInputs[port]), true);
    // do not disable analog reporting on these 8 pins, to allow some
    // pins used for digital, others analog.  Instead, allow both types
    // of reporting to be enabled, but check if the pin is configured
    // as analog when sampling the analog inputs.  Likewise, while
    // scanning digital pins, portConfigInputs will mask off values from any
    // pins configured as analog
   SYSEX-BASED commands
void sysexCallback(byte command, byte argc, byte *argv) {
    byte mode;
    byte stopTX;
    byte slaveAddress;
    byte data;
    int slaveRegister;
    unsigned int delayTime;
    byte pin;
    int frequency;
    int duration;
    switch (command) {
        case RU_THERE:
            Firmata.write(START_SYSEX);
            Firmata.write((byte) I_AM_HERE);
            Firmata.write((byte) ARDUINO_INSTANCE_ID);
            Firmata.write(END_SYSEX);
        case I2C_REQUEST:
            mode = argv[1] & I2C_READ_WRITE_MODE_MASK;
            if (argv[1] & I2C_10BIT_ADDRESS_MODE_MASK) {
                Firmata.sendString("10-bit addressing not supported");
                return;
                slaveAddress = argv[0];
            // need to invert the logic here since 0 will be default for client
            // libraries that have not updated to add support for restart tx
            if (argv[1] & I2C_END_TX_MASK) {
                stopTX = I2C_RESTART_TX;
                stopTX = I2C_STOP_TX; // default
            switch (mode) {
                case I2C_WRITE:
                    Wire.beginTransmission(slaveAddress);
                    for (byte i = 2; i < argc; i += 2) {
                        data = argv[i] + (argv[i + 1] << 7);
                        wireWrite(data);
                    Wire.endTransmission();
                    delayMicroseconds(70);
                case I2C_READ:
                    if (argc == 6) {
                        // a slave register is specified
                        slaveRegister = argv[2] + (argv[3] << 7);
                        data = argv[4] + (argv[5] << 7);  // bytes to read
                        // a slave register is NOT specified
                        slaveRegister = I2C_REGISTER_NOT_SPECIFIED;
                        data = argv[2] + (argv[3] << 7);  // bytes to read
                    readAndReportData(slaveAddress, (int) slaveRegister, data, stopTX);
                case I2C_READ_CONTINUOUSLY:
                    if ((queryIndex + 1) >= I2C_MAX_QUERIES) {
                        // too many queries, just ignore
                        Firmata.sendString("too many queries");
                    if (argc == 6) {
                        slaveRegister = (int) I2C_REGISTER_NOT_SPECIFIED;
                    queryIndex++;
                    query[queryIndex].addr = slaveAddress;
                    query[queryIndex].reg = slaveRegister;
                    query[queryIndex].bytes = data;
                    query[queryIndex].stopTX = stopTX;
                case I2C_STOP_READING:
                    byte queryIndexToSkip;
                    // if read continuous mode is enabled for only 1 i2c device, disable
                    // read continuous reporting for that device
                    if (queryIndex <= 0) {
                        queryIndex = -1;
                        queryIndexToSkip = 0;
                        // if read continuous mode is enabled for multiple devices,
                        // determine which device to stop reading and remove it's data from
                        // the array, shifiting other array data to fill the space
                        for (byte i = 0; i < queryIndex + 1; i++) {
                            if (query[i].addr == slaveAddress) {
                                queryIndexToSkip = i;
                        for (byte i = queryIndexToSkip; i < queryIndex + 1; i++) {
                            if (i < I2C_MAX_QUERIES) {
                                query[i].addr = query[i + 1].addr;
                                query[i].reg = query[i + 1].reg;
                                query[i].bytes = query[i + 1].bytes;
                                query[i].stopTX = query[i + 1].stopTX;
                        queryIndex--;
                default:
        case I2C_CONFIG:
            delayTime = (argv[0] + (argv[1] << 7));
            if (argc > 1 && delayTime > 0) {
                i2cReadDelayTime = delayTime;
            if (!isI2CEnabled) {
                enableI2CPins();
        case SERVO_CONFIG:
            if (argc > 4) {
                // these vars are here for clarity, they'll optimized away by the compiler
                byte pin = argv[0];
                int minPulse = argv[1] + (argv[2] << 7);
                int maxPulse = argv[3] + (argv[4] << 7);
                        detachServo(pin);
                    attachServo(pin, minPulse, maxPulse);
                    setPinModeCallback(pin, PIN_MODE_SERVO);
            case KEEP_ALIVE:
      keepAliveInterval = argv[0] + (argv[1] << 7);
      previousKeepAliveMillis = millis();
#endif
        case SAMPLING_INTERVAL:
            if (argc > 1) {
                samplingInterval = argv[0] + (argv[1] << 7);
                if (samplingInterval < MINIMUM_SAMPLING_INTERVAL) {
                    samplingInterval = MINIMUM_SAMPLING_INTERVAL;
                /* calculate number of loops per ping */
                numLoops = INTER_PING_INTERVAL / samplingInterval;
                /* calculate number of loops between each sample of DHT data */
                dhtNumLoops = DHT_INTER_PING_INTERVAL / samplingInterval;
                //Firmata.sendString("Not enough data");
        case EXTENDED_ANALOG:
            if (argc > 1) {
                int val = argv[1];
                if (argc > 2) val |= (argv[2] << 7);
                if (argc > 3) val |= (argv[3] << 14);
                analogWriteCallback(argv[0], val);
        case CAPABILITY_QUERY:
            Firmata.write(CAPABILITY_RESPONSE);
            for (byte pin = 0; pin < TOTAL_PINS; pin++) {
                    Firmata.write((byte) INPUT);
                    Firmata.write(1);
                    Firmata.write((byte) PIN_MODE_PULLUP);
                    Firmata.write(1);
                    Firmata.write((byte) OUTPUT);
                    Firmata.write(1);
                    Firmata.write((byte) PIN_MODE_STEPPER);
                    Firmata.write(1);
                    Firmata.write((byte) PIN_MODE_SONAR);
                    Firmata.write(1);
                    Firmata.write((byte) PIN_MODE_DHT);
                    Firmata.write(1);
                    Firmata.write((byte)PIN_MODE_TONE);
          Firmata.write(1);
#endif
                    Firmata.write(PIN_MODE_ANALOG);
                    Firmata.write(10); // 10 = 10-bit resolution
                    Firmata.write(PIN_MODE_PWM);
                    Firmata.write(DEFAULT_PWM_RESOLUTION);
                    Firmata.write(PIN_MODE_SERVO);
                    Firmata.write(14);
                    Firmata.write(PIN_MODE_I2C);
                    Firmata.write(1);  // TODO: could assign a number to map to SCL or SDA
                serialFeature.handleCapability(pin);
#endif
                Firmata.write(127);
        case PIN_STATE_QUERY:
            if (argc > 0) {
                byte pin = argv[0];
                Firmata.write(PIN_STATE_RESPONSE);
                Firmata.write(pin);
                    Firmata.write(Firmata.getPinMode(pin));
                    Firmata.write((byte) Firmata.getPinState(pin) & 0x7F);
                    if (Firmata.getPinState(pin) & 0xFF80) Firmata.write((byte)(Firmata.getPinState(pin) >> 7) & 0x7F);
                    if (Firmata.getPinState(pin) & 0xC000) Firmata.write((byte)(Firmata.getPinState(pin) >> 14) & 0x7F);
        case ANALOG_MAPPING_QUERY:
            Firmata.write(ANALOG_MAPPING_RESPONSE);
                Firmata.write(IS_PIN_ANALOG(pin) ? PIN_TO_ANALOG(pin) : 127);
        case SERIAL_MESSAGE:
            serialFeature.handleSysex(command, argc, argv);
#endif
            case TONE_DATA:
      byte toneCommand, pin;
      int frequency, duration;
      toneCommand = argv[0];
      pin = argv[1];
      if (toneCommand == TONE_TONE) {
        frequency = argv[2] + (argv[3] << 7);
        // duration is currently limited to 16,383 ms
        duration = argv[4] + (argv[5] << 7);
        tone(pin, frequency, duration);
      else if (toneCommand == TONE_NO_TONE) {
        noTone(pin);
      break ;
#endif
            // arg0 = trigger pin
            // arg1 = echo pin
            // arg2 = timeout_lsb
            // arg3 = timeout_msb
        case SONAR_CONFIG :
            unsigned long timeout;
            if (numActiveSonars < MAX_SONARS) {
                sonarTriggerPin = argv[0];
                sonarEchoPin = argv[1];
                timeout = argv[2] + (argv[3] << 7);
                sonarPinNumbers[numActiveSonars] = sonarTriggerPin;
                setPinModeCallback(sonarTriggerPin, PIN_MODE_SONAR);
                setPinModeCallback(sonarEchoPin, PIN_MODE_SONAR);
                sonars[numActiveSonars] = new Ultrasonic(sonarTriggerPin, sonarEchoPin, timeout);
                numActiveSonars++;
                Firmata.sendString("PING_CONFIG Error: Exceeded number of supported ping devices");
        case STEPPER_DATA:
            // determine if this a STEPPER_CONFIGURE command or STEPPER_OPERATE command
            if (argv[0] == STEPPER_CONFIGURE) {
                int numSteps = argv[1] + (argv[2] << 7);
                int pin1 = argv[3];
                int pin2 = argv[4];
                if (argc == 5) {
                    // two pin motor
                    stepper = new Stepper(numSteps, pin1, pin2);
                } else if (argc == 7) // 4 wire motor
                    int pin3 = argv[5];
                    int pin4 = argv[6];
                    stepper = new Stepper(numSteps, pin1, pin2, pin3, pin4);
                    Firmata.sendString("STEPPER CONFIG Error: Wrong Number of arguments");
                    printData((char *) "argc = ", argc);
            } else if (argv[0] == STEPPER_STEP) {
                long speed = (long) argv[1] | ((long) argv[2] << 7) | ((long) argv[3] << 14);
                int numSteps = argv[4] + (argv[5] << 7);
                int direction = argv[6];
                if (stepper != NULL) {
                    stepper->setSpeed(speed);
                    if (direction == 0) {
                        numSteps *= -1;
                    stepper->step(numSteps);
                    Firmata.sendString("STEPPER OPERATE Error: MOTOR NOT CONFIGURED");
            } else if (argv[0] == STEPPER_LIBRARY_VERSION) {
                    int version = stepper->version();
                    Firmata.write(STEPPER_DATA);
                    Firmata.write(version & 0x7F);
                    Firmata.write(version >> 7);
                    // did not find a configured stepper
                    Firmata.sendString("STEPPER FIRMWARE VERSION Error: NO MOTORS CONFIGURED");
                Firmata.sendString("STEPPER CONFIG Error: UNKNOWN STEPPER COMMAND");
        case DHT_CONFIG:
            int DHT_Pin = argv[0];
            int DHT_type = argv[1];
            if (numActiveDHTs < MAX_DHTS) {
                if (DHT_type != 22 && DHT_type != 11) {
                    Firmata.sendString("ERROR: UNKNOWN SENSOR TYPE, VALID SENSORS ARE 11, 22");
                    // test the sensor
                    DHT_PinNumbers[numActiveDHTs] = DHT_Pin;
                    DHT_TYPE[numActiveDHTs] = DHT_type;
                    setPinModeCallback(DHT_Pin, PIN_MODE_DHT);
                    numActiveDHTs++;
                    dhtNumLoops = dhtNumLoops / numActiveDHTs;
                Firmata.sendString("DHT_CONFIG Error: Exceeded number of supported DHT devices");
   SETUP()
void systemResetCallback() {
    isResetting = true;
    // initialize a defalt state
    // TODO: option to load config from EEPROM instead of default
    serialFeature.reset();
#endif
    if (isI2CEnabled) {
        disableI2CPins();
    for (byte i = 0; i < TOTAL_PORTS; i++) {
        reportPINs[i] = false;    // by default, reporting off
        portConfigInputs[i] = 0;  // until activated
        previousPINs[i] = 0;
    for (byte i = 0; i < TOTAL_PINS; i++) {
        // pins with analog capability default to analog input
        // otherwise, pins default to digital output
        if (IS_PIN_ANALOG(i)) {
            // turns off pullup, configures everything
            setPinModeCallback(i, PIN_MODE_ANALOG);
            else if ( IS_PIN_TONE(i)) {
      noTone(i) ;
#endif
        else {
            // sets the output to 0, configures portConfigInputs
            setPinModeCallback(i, OUTPUT);
        servoPinMap[i] = 255;
    // stop pinging
    for (int i = 0; i < MAX_SONARS; i++) {
        sonarPinNumbers[i] = PIN_MODE_IGNORE;
        if (sonars[i]) {
            sonars[i] = NULL;
    // by default, do not report any analog inputs
    servoCount = 0;
    // stop pinging DHT
    numActiveDHTs = 0;
    /* send digital inputs to set the initial state on the host computer,
      since once in the loop(), this firmware will only send on change */
      TODO: this can never execute, since no pins default to digital input
          but it will be needed when/if we support EEPROM stored config
      for (byte i=0; i < TOTAL_PORTS; i++) {
      outputPort(i, readPort(i, portConfigInputs[i]), true);
    Firmata.setFirmwareVersion(FIRMATA_FIRMWARE_MAJOR_VERSION, FIRMATA_FIRMWARE_MINOR_VERSION);
    Firmata.attach(ANALOG_MESSAGE, analogWriteCallback);
    Firmata.attach(DIGITAL_MESSAGE, digitalWriteCallback);
    Firmata.attach(REPORT_ANALOG, reportAnalogCallback);
    Firmata.attach(REPORT_DIGITAL, reportDigitalCallback);
    Firmata.attach(SET_PIN_MODE, setPinModeCallback);
    Firmata.attach(SET_DIGITAL_PIN_VALUE, setPinValueCallback);
    Firmata.attach(START_SYSEX, sysexCallback);
    Firmata.attach(SYSTEM_RESET, systemResetCallback);
    // to use a port other than Serial, such as Serial1 on an Arduino Leonardo or Mega,
    // Call begin(baud) on the alternate serial port and pass it to Firmata to begin like this:
    // Serial1.begin(115200);
    // Firmata.begin(Serial1);
    // However do not do this if you are using SERIAL_MESSAGE
    Firmata.begin(115200);
    while (!Serial) {
        ; // wait for serial port to connect. Needed for ATmega32u4-based boards and Arduino 101
    systemResetCallback();  // reset to default config
   LOOP()
    byte pin, analogPin;
    /* DIGITALREAD - as fast as possible, check for changes and output them to the
       FTDI buffer using Serial.print()  */
    checkDigitalInputs();
    /* STREAMREAD - processing incoming messagse as soon as possible, while still
       checking digital inputs.  */
    while (Firmata.available())
        Firmata.processInput();
    // TODO - ensure that Stream buffer doesn't go over 60 bytes
    currentMillis = millis();
    if (currentMillis - previousMillis > samplingInterval) {
        previousMillis += samplingInterval;
        if (pingLoopCounter++ > numLoops) {
            if (numActiveSonars) {
                unsigned int distance = sonars[nextSonar]->read();
                currentSonar = nextSonar;
                if (nextSonar++ >= numActiveSonars - 1) {
                    nextSonar = 0;
                sonarLSB = distance & 0x7f;
                sonarMSB = distance >> 7 & 0x7f;
                Firmata.write(SONAR_DATA);
                Firmata.write(sonarPinNumbers[currentSonar]);
                Firmata.write(sonarLSB);
                Firmata.write(sonarMSB);
        if (dhtLoopCounter++ > dhtNumLoops) {
            if (numActiveDHTs) {
                int rv;
                float humidity, temperature;
                uint8_t current_pin = DHT_PinNumbers[nextDHT];
                uint8_t current_type = DHT_TYPE[nextDHT];
                dhtLoopCounter = 0;
                currentDHT = nextDHT;
                if (nextDHT++ >= numActiveDHTs - 1) {
                    nextDHT = 0;
                // clear out the data buffer
                for (int i = 0; i < 4; i++) {
                    dht_value[i] = (uint8_t) 0;
                if (current_type == 22) {
                    rv = DHT.read22(current_pin);
                    rv = DHT.read11(current_pin);
                if (rv == DHTLIB_OK) {
                    float i, f;
                    humidity = DHT.getHumidity();
                    f = modff(humidity, &i);
                    dht_value[0] = (uint8_t)i;
                    dht_value[1] = (uint8_t)(f * 100);
                    temperature = DHT.getTemperature();
                    f = modff(temperature, &i);
                    dht_value[2] = (uint8_t)i;
                    dht_value[3] = (uint8_t)(f * 100);
                // send the message back with an error status
                Firmata.write(DHT_DATA);
                Firmata.write(current_pin);
                Firmata.write(current_type);
                Firmata.write(abs(rv));
                if (humidity >= 0.0) {
                    Firmata.write(0);
                else {
                    Firmata.write(1);
                if (temperature >= 0.0) {
                    Firmata.write(0);
                else {
                    Firmata.write(1);
                for (uint8_t i = 0; i < 4; ++i) {
                    Firmata.write(dht_value[i]);
        /* ANALOGREAD - do all analogReads() at the configured sampling interval */
        for (pin = 0; pin < TOTAL_PINS; pin++) {
            if (IS_PIN_ANALOG(pin) && Firmata.getPinMode(pin) == PIN_MODE_ANALOG) {
                analogPin = PIN_TO_ANALOG(pin);
                if (analogInputsToReport & (1 << analogPin)) {
        // report i2c data for all device with read continuous mode enabled
        if (queryIndex > -1) {
                readAndReportData(query[i].addr, query[i].reg, query[i].bytes, query[i].stopTX);
        if ( keepAliveInterval ) {
      if (currentMillis - previousKeepAliveMillis > keepAliveInterval * 1000) {
        wdt_enable(WDTO_15MS);
        // systemResetCallback();
        while (1)
#endif
    serialFeature.update();
#endif
void printData(char *id, long data) {
    char myArray[64];
    String myString = String(data);
    myString.toCharArray(myArray, 64);
    Firmata.sendString(id);
    Firmata.sendString(myArray);
pardon me, can you help me out to find the solution?
As the author of pymata-express, I suggest you move over to Telemetrix. It uses the AccelStepper library to control stepper motors and is available in both asyncio and non-asyncio flavors.
Please note that pymata-express has been archived.
If you have any issues with Telemetrix, please generate an issue in GitHub.
