pyserial communicate with two separate arduinos
Can I use pyserial to communicate with two separate arduinos? The arduinos are plugged into usb ports on a windows 7 os, but will eventually be plugged in to a raspberry pi.
I tried it in python and it didn't work is there a way to do this.
I doubt,I also tried initially to communicate 2 Serial Device using python.We can communicate one device at time. ELse you try to connect / communicate using different py scripted version
I'm not familiar with PySerial but I would be surprised if you can't open communications with two separate Com ports?
...R
Pyserial com ports are represented by objects. There's no reason that I know of you couldn't create two objects. I've used pyserial to do something similar with a one wire multi drop bus protocol but I haven't personally tried using 2 pyserial.Serial objects. But Im pretty sure I've seen it discussed and done successfully on stack overflow.
