Pyserial Transfer From One Port to Another Port
I have a flight computer and ground station which is based on arduino. Flight computer transmits sensors data to ground station with rf communication modules. So, I'm trying to write a program for getting data's from ground station then send to another computer with serial communication. Actually I did the sending part with user input. This is the program:
import struct
import time
import serial
array1 = bytearray(78)
array1[0:4] = bytes.fromhex('FFFF5452')
array1[76:78] = bytes.fromhex('0d0a')
altitude = float(input("altitude: "))
gps_altitude = float(input("gps altitude: "))
latitude = float(input("latitude: "))
longitude = float(input("longitude: "))
payload_altitude = float(input("payload altitude: "))
payload_latitude = float(input("payload latitude: "))
payload_longitude = float(input("payload longitude: "))
array1[6:34] = struct.pack('<7f', altitude, gps_altitude, latitude, longitude, payload_altitude, payload_latitude, payload_longitude)
with serial.Serial('COM16', 19200, serial.EIGHTBITS, serial.PARITY_NONE, serial.STOPBITS_ONE) as ser:
    while True:
        array[75] = sum(array[4:75]) % 256
        ser.write(array1)
        array1[5] += 1
        time.sleep(3)
This is working for sending user inpt to other pc via com port.
I couldn't get sensor data from arduino instead of user inputs
this is the code for the ground station where i am trying to get the data (arduino)
struct Signal {
  byte langt[4];
  byte longt[4];
} data;
byte i;
  Serial3.begin(9600);
  while (Serial3.available()) {
    receive(&data);
    Serial.print("langt:");
    Serial.println((*(float *)(data.langt)), 6);
    Serial.print("longt  :");
    Serial.println((*(float *)(data.longt)), 6);
bool receive(Signal *table) {
  return (Serial3.readBytes((uint8_t *)table, sizeof(Signal)) == sizeof(Signal));
How can I edit the above python program to transfer data coming from arduino?
transferring multi-byte data requires knowing the start and end of the packet of information.
the receiver typically monitors the input for a start "sequence", discarding bytes until found and even then, the actual data my "look" like the start sequence and a checksum is needed to verify that a valid packet has been received.
encoding the data in ascii is less efficient, but easier to handle because a common "end" character is a newline, '\n', or carriage return '\r' and on arduino, Serial.readBytesUntil() would conveniently read the "line" representing the packet of data
