pySerialTransfer Two Way Communication Issues
I wrote a basic two way python and serial communication script that sends an integer to the arduino. Then, the arduino increments the integer and sends it back over serial.
comm.py
from time import sleep
from pySerialTransfer import pySerialTransfer as txfer
class struct:
    control = 0
class receivestruct:
    status = 0
if __name__ == '__main__':
    try:
        testStruct = struct
        rstruct =receivestruct
        link = txfer.SerialTransfer('COM7')
        link.open()
        sleep(2)
        counter = 0
        while True:
            sendSize = 0
            testStruct.control = counter
            sendSize = link.tx_obj(testStruct.control, start_pos=sendSize)
            link.send(sendSize)
            print('sent')
            #sleep(0.5)
            read_correctly = False
            while (read_correctly == False):
                try:
                    if not (link.available()):
                        pass
                    recSize = 0
                    # this section returns errors with can't read str as int
                    rstruct.status = link.rx_obj(obj_type='i', start_pos=recSize)
                    counter = rstruct.status
                    recSize += txfer.STRUCT_FORMAT_LENGTHS['i']
                    print(rstruct.status)
                    read_correctly = True
                except:
                    pass
    except KeyboardInterrupt:
        link.close()
arduino.ino
#include "SerialTransfer.h"
SerialTransfer myTransfer;
uint32_t rcontrol;
uint32_t control;
  myTransfer.begin(Serial);
  if(myTransfer.available())
    // use this variable to keep track of how many
    // bytes we've processed from the receive buffer
    uint16_t recSize = 0;
    recSize = myTransfer.rxObj(rcontrol, recSize);
    control = rcontrol + 1;
    uint16_t sendSize = 0;
    sendSize = myTransfer.txObj(control, sendSize);
    myTransfer.sendData(sendSize);
Now, I thought this would work properly. However, here is the console log, where it seems like python is not reading the incremented value properly, and only reads the correct incremented value every n attempts:
115
sent
115
sent
116
sent
116
sent
116
sent
116
sent
116
sent
116
sent
116
sent
116
sent
116
sent
117
sent
117
sent
117
sent
117
sent
117
sent
117
sent
117
sent
117
sent
117
sent
118
sent
118
sent
118
sent
118
sent
118
sent
118
sent
118
sent
118
sent
118
sent
119
sent
119
sent
119
sent
119
sent
119
sent
119
sent
119
sent
119
sent
I tried the two way example for pySerialTransfer here, but it appears to use an outdated version of the library that is no longer supported. Any idea why I am seeing these issue with two way serial communication?
import serial, time
Arduino = serial.Serial("/dev/ttyACM0", "115200", timeout=1)
Arduino.setDTR(False)
sleep(1)
Arduino.flushInput()
Arduino.setDTR(True)
num = 0
try:
    Arduino.print('1')
    time.sleep(1)
except:
    pass
while True:
    if (Arduino.isOpen() == False):
        Arduino.open()
    if Arduino.inWaiting() > 0:
        try:
            income = Arduino.readline().decode().strip()
            num = int(income) + 1
            Arduino.print(num)
            print("sent " + num)
            time.sleep(1)
        except:
            pass
  if (Serial.available() > 0)  {
    int i = Serial.parseInt();
    Serial.print(i + 1);
    Serial.write(0xa);
Thanks for the code! Arduino sides works fine but the python script doesn't seem to work for me; nothing is ever printed on the PC console side.
ok. corrected.
It appear that Serial.print isn't working. If I get rid of the try except statement, I get this error:
Arduino.print('1')
AttributeError: 'Serial' object has no attribute 'print'
I’ve written a small tutorial on interfacing with Python. See Two ways communication between Python3 and Arduino
Thank you for the tutorial. I just ran your code, and I'm getting utf-8 decode errors:
PORT    DEVICE                  MANUFACTURER
0        COM7    Arduino Srl (www.arduino.org)
➜ Select your port: 0
selecting:  COM7
Waiting for Arduino
Exception in thread Thread-1 (listenToArduino):
Traceback (most recent call last):
  File "C:\Users\sshen\AppData\Local\Programs\Python\Python312\Lib\threading.py", line 1073, in _bootstrap_inner
    self.run()
  File "C:\Users\sshen\AppData\Local\Programs\Python\Python312\Lib\threading.py", line 1010, in run
    self._target(*self._args, **self._kwargs)
  File "C:\Users\sshen\OneDrive - ICI\Desktop\alt-min\comm.py", line 60, in listenToArduino
    arduinoQueue.put(message.decode('utf-8').strip().upper())
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xf0 in position 0: unexpected end of data
I'm not quite sure why this is happening. Do you know why?
  Serial.println(1);
  static uint32_t oldMil = 0;
  static int16_t num = 1;
    byte pEek = Serial.peek();
    if (pEek < 32 || pEek > 127) {
      Serial.read();
      return;
    if (i == 0)return;
    num = i + 1;
    Serial.print(num);
    Serial.write(0xA);
    oldMil = millis();
  if (millis() - oldMil > 2000) {
    oldMil = millis();
    Serial.println(num);
import serial, time
Arduino = serial.Serial("COM4", "115200", timeout=1)
sleep(1)
sleep(3)
num = 0
print("start")
while True:
        Arduino.open()
        try:
            i = int(income)
            if(i==0):
            num = i + 1
            line = str(num)
            Arduino.write(line.encode())
            print("sent " + line)
            time.sleep(1)
        except:
            pass
Did you install the code on the arduino as well ?
‘utf-8’ with the single quotes is different than the c-string “utf-8”. Perhaps this is your error?
Yes, I did. Same after reflashing.
if you open IDE serial port, do you able to test arduino's uploaded sketch?
Yes, it works as expected, echoing back whatever I send at it.
and incrementing
or you using not my sketch?
My apologies, your sketch works. I was referring to @J-M-L's code.
and python?
Are you using UTF8 in your text editor on windows ?
