Python and Arduino serial
I'm trying to send data to Arduino UNO using Python
the Arduino code
const int controlPin = 9;
void setup(){
  pinMode(controlPin, OUTPUT);
  digitalWrite(controlPin, HIGH);
void loop(){
if (Serial.available() > 0) {
    int inByte = Serial.read();
    switch (inByte) {
    case '0':
     digitalWrite(controlPin, LOW);
    case '1':
this code is working when i open the Arduino ide and open the serial monitor and send 0 it turn off when i send 1 it turn on
im trying to do the same thing without using the ide i want to use python
i tried the following
import serial # if you have not already done so
ser = serial.Serial('/dev/ttyACM0', 9600)
ser.write('x')
anything i type in the x place it turn it on even if i typed 0 or 1 they both turn it on
any ideas ?
opening the serial port in Python will reset the Arduino
try this
import serial
ser = serial.Serial("COM31", 115200)
def main():
    ser.close()
    ser.open()
    while(True):
	print ser.inWaiting()
        print ser.read(1)
if __name__ == '__main__':
    main()
The Python demo that I posted in this Thread may be of interest.
...R
