SRJ
June 30, 2022, 2:58pm
1
Hi everybody,
I recently bought ESP-WROOM-32
but, I am not able to compile code for it
& the below ERROR message is seen
Arduino: 1.8.19 (Linux), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
exec: "python": executable file not found in $PATH
Error compiling for board ESP32 Dev Module.
option enabled in File -> Preferences.
and also I am unable to find 'ESP-WROOM-32' in board selector of ARDUINO
please help
Update the boards menu from file>preferences
Use the phrase "arduino update boards menu" with your favorite search engine.
There may not be one with the exact name "ESP-WROOM-32" but others, like "ESP32 dev module" will probably work. Try a few and check the listed specifications against those for your module.
SRJ
June 30, 2022, 3:08pm
6
Hey,
My Board menu is updated
but still the same error............
J-M-L
June 30, 2022, 3:18pm
7
see this for how we solved it on a Mac
running this command in Terminal.app under your current user
sed -i -e 's/=python /=python3 /g' ~/Library/Arduino15/packages/esp32/hardware/esp32/*/platform.txt
seems to fix it.The command modifies all the platform.txt files under your local installation of the ESP32 tools (~/Library/Arduino15/packages/esp32/hardware/esp32) and replaces the word python by python3 wherever it finds it
(cf Deprecation of Python 2. Solution · Issue #4717 · espressif/arduino-esp32 · GitHub )
may be it's similar on linux and you need a direct call to python3
SRJ
June 30, 2022, 3:27pm
8
Hey J-M-l
Thanks for your support
but
MAC commands are not supported in LINUX
sed certainly does run under linux. You may have to install it.
Type sed on the command line and tell us what you see.
J-M-L
June 30, 2022, 3:30pm
10
Mac is running Unix under the hood (trademarked ), open a terminal and you can enter the same commands.
file locations will differ and you need to make sure this is really the problem you face before you change all the python into python3 in your platforms
SRJ
June 30, 2022, 3:32pm
11
sed: can't read /home/sandeep/Library/Arduino15/packages/esp32/hardware/esp32/*/platform.txt: No such file or directory
So, sed is installed and running!
Do you have a user named "sandeep" on your linux system?
J-M-L
June 30, 2022, 3:34pm
13
yeah, as mentioned your file location will be different
it's likely a hidden folder like home/{username}/.arduino15
BUT PLEASE MAKE SURE THIS IS THE ISSUE AT HAND BEFORE APPLYING THE CHANGES (or make a back up of these files)
what do you see if you run
ls -al /home/sandeep/.arduino15/
and
ls -al /home/sandeep/.arduino15/packages
MrMark
June 30, 2022, 3:38pm
14
There is an explicit list of the Linux files and changes in this post: https://github.com/espressif/arduino-esp32/issues/4717#issuecomment-1070801525
You should be able to use your text editor of choice and make these changes.
"sed" is just an efficient but somewhat obscure way to do the same thing (welcome to Linux! ) in one line.
SRJ
June 30, 2022, 3:39pm
15
for ls -al /home/sandeep/.arduino15/
total 26620
drwxr-xr-x 1 sandeep sandeep 400 Jun 30 20:45 .
drwxr-xr-x 1 sandeep sandeep 1794 Jun 30 19:45 ..
drwxr-xr-x 1 sandeep sandeep 180 Jun 20 22:00 cache
-rw-rw-r-- 1 sandeep sandeep 26423265 Jun 29 08:15 library_index.json
-rw-rw-r-- 1 sandeep sandeep 543 Jun 29 08:15 library_index.json.sig
drwxr-xr-x 1 sandeep sandeep 30 Aug 16 2021 logs
-rw-rw-r-- 1 sandeep sandeep 24504 Jun 30 20:45 package_esp32_index.json
-rw-rw-r-- 1 sandeep sandeep 159588 Jun 30 20:45 package_esp8266com_index.json
-rw-rw-r-- 1 sandeep sandeep 514288 Jun 30 20:45 package_index.json
-rw-rw-r-- 1 sandeep sandeep 543 Jun 30 20:45 package_index.json.sig
drwxr-xr-x 1 sandeep sandeep 24 Jun 21 19:19 packages
-rw-rw-r-- 1 sandeep sandeep 111323 Jun 20 22:00 package_spacehuhn_index.json
-rw------- 1 sandeep sandeep 9461 Jun 30 19:33 preferences.txt
drwxr-xr-x 1 sandeep sandeep 34 Aug 31 2021 staging
& for ls -al /home/sandeep/.arduino15/packages its
total 0
drwxr-xr-x 1 sandeep sandeep 24 Jun 21 19:19 .
drwxr-xr-x 1 sandeep sandeep 400 Jun 30 20:45 ..
drwxrwxr-x 1 sandeep sandeep 26 Jun 21 19:19 esp32
drwxr-xr-x 1 sandeep sandeep 26 Aug 16 2021 esp8266
J-M-L
June 30, 2022, 3:41pm
16
OK
make a copy of
/home/sandeep/.arduino15/packages/esp32
then issue that command
sed -i -e 's/=python /=python3 /g' ~/.arduino15/packages/esp32/hardware/esp32/*/platform.txt
that's the same command as for the Mac, but using ~/.arduino15 as the target directory
SRJ
July 1, 2022, 1:07pm
18
I found the solution while browsing on the Internet
sudo usermod -a -G dialout $USER && sudo apt-get install git && wget https://bootstrap.pypa.io/get-pip.py && sudo python3 get-pip.py && sudo pip3 install pyserial && mkdir -p ~/Arduino/hardware/espressif && cd ~/Arduino/hardware/espressif && git clone https://github.com/espressif/arduino-esp32.git esp32 && cd esp32/tools && python3 get.py
just PASTE above command lines in LINUX TERMINAL.
system
Closed
December 28, 2022, 1:07pm
19
