Hello my project sends data from the Arduino to Python so that python does an action when a certain value has been read from the serial.
The Arduino sends a Serial.println("s");
Then Python interprets it with
import serial
import time
import pyautogui
import keyboard
from pynput import mouse
from pynput.mouse import Button, Controller
arduino = serial.Serial(port='COM3', baudrate=9600, timeout=.01)
def issensed():
data = arduino.readline()
return data
while (True):
value = str(issensed())
if value == "s":
pyautogui.typewrite("hi")
else:
pyautogui.typewrite("no")
However hi is not being written and no is not being written.
#!/usr/bin/env python3
import serial
import time
arduino = serial.Serial(port='COM3', baudrate=115200, timeout=.1)
def arduinoRead():
return data
while True:
value = arduinoRead()
if value != b'':
print(value)
of course make sure COM3 is where you arduino is connected and don't open the IDE serial monitor
==> note that you get the \r\n from the println() in the resulting data so this is to be taken into account if you want to do some testing against that string
yes, as I wrote you have the "\r\n" in your result, so your compare is wrong
import serial
import time
def arduinoRead():
return data
while True:
if value != b'':
print(value) # printing the value
if value == b's\r\n':
print("this is what I expected")
if you run this, you should now see
b'Arduino boot\r\n'
b's\r\n'
b's\r\n'
b's\r\n'
b's\r\n'
b's\r\n'
b's\r\n'
b's\r\n'
