Python module for Nick Gammon's RS485 library?
Hi.
I want to use Nick Gammon's RS485 library for communications between an Arduino and a Raspberry Pi.
On the Raspbery Pi I am using python.
Does anybody know of a python implementation of the protocol? (I tried searching for one but came up empty.)
If no module exists I will port the protocol and publish the result on GitHub.
Best regards,
Søren.
PS: Thanks for providing the library Nick.
Not seen a port here, so it would be great if you could port it to Python,
OK - I will give it a try then. Thanks for replying.
OK, first take is ready at GitHub - Sthing/Nick-Gammon-RS485: Python implementation of Nick Gammon's RS485 library for the Arduino.
Currently only tested python-to-python, testing against Nick Gammon's original library is next on my to do list.
A quick look,
seems like you did a decent job, thanks for sharing!
Hi Soren,
Thank you for sharing this !
Did you test it with an Arduino ? I'm actually planning to do exactly the same, to control arduinos through Domoticz, installed on the Rasp Pi.
Is there any consideration to take care of to get it work ? version of Python or whatever ?
I guess you used an USB to RS485 converter ?
Thank you !
