I have been trying to send a list of data from my controller connected to python to the Arduino transmitter, so I can control my plane from the receiver. I have been able to send a list from python using PySerialTransfer to the transmitter, however, when I try to send that list to the receiver I am only able to send the first value in the list, the other values are 0. Any advice would be greatly appreciated.
Here is the python code:
[color=#a9b7c6][color=#cc7832]import [/color]time
[color=#cc7832]from [/color]pySerialTransfer [color=#cc7832]import [/color]pySerialTransfer [color=#cc7832]as [/color]txfer
[color=#cc7832]if [/color]__name__ == [color=#6a8759]'__main__'[/color]:
[color=#cc7832]try[/color]:
link = txfer.SerialTransfer([color=#6a8759]'COM3'[/color])
link.open()
time.sleep([color=#6897bb]2[/color]) [color=#808080]# allow
[/color][color=#808080] # time for the Arduino to completely reset
[/color]
[color=#cc7832]while True[/color]:
send_size = [color=#6897bb]0
[/color]
[color=#808080]###################################################################
[/color][color=#808080] # Send a list
[/color][color=#808080] ###################################################################
[/color] list_ = [[color=#6897bb]5[/color][color=#cc7832], [/color][color=#6897bb]1[/color]]
list_size = link.tx_obj(list_)
send_size += list_size
[/color][color=#808080] # Transmit all the data to send in a single packet
[/color] link.send(send_size)
[/color][color=#808080] # Wait for a response and report any errors while receiving packets
[/color] [color=#cc7832]while not [/color]link.available():
[color=#cc7832]if [/color]link.status < [color=#6897bb]0[/color]:
[color=#cc7832]if [/color]link.status == txfer.CRC_ERROR:
[color=#8888c6]print[/color]([color=#6a8759]'ERROR: CRC_ERROR'[/color])
[color=#cc7832]elif [/color]link.status == txfer.PAYLOAD_ERROR:
[color=#8888c6]print[/color]([color=#6a8759]'ERROR: PAYLOAD_ERROR'[/color])
[color=#cc7832]elif [/color]link.status == txfer.STOP_BYTE_ERROR:
[color=#8888c6]print[/color]([color=#6a8759]'ERROR: STOP_BYTE_ERROR'[/color])
[color=#cc7832]else[/color]:
[color=#8888c6]print[/color]([color=#6a8759]'ERROR: {}'[/color].format(link.status))
[/color][color=#808080] # Parse response list
[/color] rec_list_ = link.rx_obj([color=#aa4926]obj_type[/color]=[color=#8888c6]type[/color](list_)[color=#cc7832],
[/color] [color=#aa4926]obj_byte_size[/color]=list_size[color=#cc7832],
[/color] [color=#aa4926]list_format[/color]=[color=#6a8759]'i'[/color])
[/color][color=#808080] # Display the received data
[/color] [color=#8888c6]print[/color]([color=#6a8759]'SENT: {} '[/color].format(list_))
[color=#8888c6]print[/color]([color=#6a8759]'RCVD: {}'[/color].format(rec_list_))
[color=#8888c6]print[/color]([color=#6a8759]' '[/color])
[color=#cc7832]except [/color][color=#8888c6]KeyboardInterrupt[/color]:
link.close()
[color=#cc7832]except[/color]:
[color=#cc7832]pass
[/color]
[color=#cc7832] except[/color]:
[color=#cc7832]import [/color]traceback
traceback.print_exc()
link.close()
[color=#cc7832]pass[/color][/color]
Here is the Arduino transmitter code:
#include "SerialTransfer.h"
#include <SPI.h> //Call SPI library so you can communicate with the nRF24L01+
#include <nRF24L01.h> //nRF2401 libarary found at GitHub - nRF24/RF24: OSI Layer 2 driver for nRF24L01 on Arduino & Raspberry Pi/Linux Devices
#include <RF24.h> //nRF2401 libarary found at GitHub - nRF24/RF24: OSI Layer 2 driver for nRF24L01 on Arduino & Raspberry Pi/Linux Devices
SerialTransfer myTransfer;
const uint8_t pinCE = 9; //This pin is used to set the nRF24 to standby (0) or active mode (1)
const uint8_t pinCSN = 10; //This pin is used to tell the nRF24 whether the SPI communication is a command
RF24 wirelessSPI(pinCE, pinCSN); // Declare object from nRF24 library (Create your wireless SPI)
const uint64_t wAddress = 0xB00B1E50C3LL; //Create pipe address to send data, the "LL" is for LongLong type
myTransfer.begin(Serial);
wirelessSPI.begin(); //Start the nRF24 module
wirelessSPI.openWritingPipe(wAddress); //open writing or transmit pipe
wirelessSPI.stopListening(); //go into transmit mode
if(myTransfer.available())
// send all received data back to Python
for(uint16_t i=0; i < myTransfer.bytesRead; i++){
wirelessSPI.write(&myTransfer.packet.rxBuff[uint16_t(0)], sizeof(myTransfer.packet.rxBuff[uint16_t(0)]));
myTransfer.packet.txBuff = myTransfer.packet.rxBuff*;*
* myTransfer.sendData(myTransfer.bytesRead);*
Here is the Arduino receiver code:
#include <nRF24L01.h> //nRF2401 libarary found at https://github.com/tmrh20/RF24/*_
_#include <RF24.h> //nRF2401 libarary found at https://github.com/tmrh20/RF24/*_
const uint8_t pinCSN = 10; //This pin is used for SPI comm chip select
const uint64_t rAddress = 0xB00B1E50C3LL; //Create pipe address for the network and notice I spelled boobies because I am mature, the "LL" is for LongLong type
const uint8_t rFChan = 89; //Set channel frequency default (chan 84 is 2.484GHz to 2.489GHz)
//Create a structure to hold fake sensor data and channel data
struct PayLoad {
* uint8_t chan;
uint8_t sensor;
_};*
PayLoad payload; //create struct object
byte list_data;
* wirelessSPI.begin(); //Start the nRF24 module*
* wirelessSPI.openReadingPipe(1,rAddress); //This is receiver or master so we need to be ready to read data from transmitters*
* wirelessSPI.startListening(); // Start listening for messages*
* Serial.begin(9600); //serial port to display received data*
* Serial.println("Network master is online...");*
* if(wirelessSPI.available()){ //Check if recieved data*
* wirelessSPI.read(&hi, sizeof(list_data)); //read packet of data and store it in struct object*
* Serial.print("Received data: ");*
* Serial.println(list_data);
_ }_
_}*_
