[Q] 8-bit atmega chip (A. Duemilanove) How to read 16-bit data?
Hello
I have Arduino Duemilanove
I have ADIS16354 inertial unit (Datasheet:
http://www.analog.com/static/imported-files/data_sheets/ADIS16354.pdf)
I know how to read data from adress, and show data using serial.print
//This is only a piece of code to read - it is complete, code work, but not correctly, often sends same values - that is not correct
Xacc_OUT 0x0A //MSB bit
Xacc_OUT 0x0B //LSB bit
pin 10               CS -     slave select
pin 11               DIN -    MOSI - Master-out, Slave-in
pin 12               DOUT -   MISO - Master-in, Slave out
pin 13               SCK -    SCLK - Serial clock
 //read x
 digitalWrite(CS,LOW);
 hi=SPI.transfer(0x0a);
 delayMicroseconds(160);
 //lo=SPI.transfer(0x0b);   // this value doesn't matter
 digitalWrite(CS,HIGH);
 data=(hi<<8);
 Serial.print("X Accel: ");
 Serial.println((hi<<8), DEC);
 delay(100);
How to read 16-bit data from specific adress 0x0A or 0x0B ?
I read guides, tutorials here on the forum on the internet, I read SPI.h library, and I still did not understand how to read 16-bit data, respectively how to combine them together.
Someone help me?
How to do it for a specific address 0x0A to the X accelerometer?
Figure 29 looks good to me.
Is this related to your other thread?
Please keep things together to save us answering twice.
Yes is my thread. Thanks for answer.
