Q on ESP web security
I'd like to secure the example code Webupdate (under ESP8266WebServer) so I combined the code with the example SimpleAuthentication.
The login part works fine, but when I choose to upgrade (myip/upgrade) the code crashes (keeps reseting for few seconds).
I really appreciate some help.
TIA
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#ifndef STASSID
#define STASSID "***"
#define STAPSK  "***"
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
ESP8266WebServer server(80);
//Check if header is present and correct
bool is_authenticated() {
  Serial.println("Enter is_authenticated");
  if (server.hasHeader("Cookie")) {
    Serial.print("Found cookie: ");
    String cookie = server.header("Cookie");
    Serial.println(cookie);
    if (cookie.indexOf("ESPSESSIONID=1") != -1) {
      Serial.println("Authentication Successful");
      return true;
  Serial.println("Authentication Failed");
  return false;
//login page, also called for disconnect
void handleLogin() {
  String msg;
  if (server.hasArg("DISCONNECT")) {
    Serial.println("Disconnection");
    server.sendHeader("Location", "/login");
    server.sendHeader("Cache-Control", "no-cache");
    server.sendHeader("Set-Cookie", "ESPSESSIONID=0");
    server.send(301);
    return;
  if (server.hasArg("USERNAME") && server.hasArg("PASSWORD")) {
    if (server.arg("USERNAME") == "admin" &&  server.arg("PASSWORD") == "admin") {
      server.sendHeader("Location", "/");
      server.sendHeader("Set-Cookie", "ESPSESSIONID=1");
      server.send(301);
      Serial.println("Log in Successful");
      return;
    msg = "Wrong username/password! try again.";
    Serial.println("Log in Failed");
  String content = "<html><body><form action='/login' method='POST'>To log in, please use : admin/admin
  content += "User:<input type='text' name='USERNAME' placeholder='user name'>
  content += "Password:<input type='password' name='PASSWORD' placeholder='password'>
  content += "<input type='submit' name='SUBMIT' value='Submit'></form>" + msg + "
  content += "You also can go <a href='/inline'>here</a></body></html>";
  server.send(200, "text/html", content);
//root page can be accessed only if authentication is ok
void handleRoot() {
  Serial.println("Enter handleRoot");
  String header;
  if (!is_authenticated()) {
    server.send(301);
    return;
  String content = "<html><body><H2>hello, you successfully connected to esp8266!</H2>
  if (server.hasHeader("User-Agent")) {
    content += "the user agent used is : " + server.header("User-Agent") + "
  content += "You can access this page until you <a href=\"/login?DISCONNECT=YES\">disconnect</a></body></html>";
//update page
void handleUpdate() {
  Serial.println("Enter update page");
    server.send(301);
    return;
  HTTPUpload& upload = server.upload();
  if (upload.status == UPLOAD_FILE_START) {
    Serial.setDebugOutput(true);
    WiFiUDP::stopAll();
    Serial.printf("Update: %s\n", upload.filename.c_str());
    uint32_t maxSketchSpace = (ESP.getFreeSketchSpace() - 0x1000) & 0xFFFFF000;
    if (!Update.begin(maxSketchSpace)) { //start with max available size
      Update.printError(Serial);
  } else if (upload.status == UPLOAD_FILE_WRITE) {
    if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
  } else if (upload.status == UPLOAD_FILE_END) {
    if (Update.end(true)) { //true to set the size to the current progress
      Serial.printf("Update Success: %u\nRebooting...\n", upload.totalSize);
    Serial.setDebugOutput(false);
  yield();
//no need authentication
void handleNotFound() {
  String message = "File Not Found\n\n";
  server.send(404, "text/plain", message);
void setup(void) {
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  // Wait for connection
    Serial.print(".");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  server.on("/", handleRoot);
  server.on("/login", handleLogin);
  server.on("/update", handleUpdate);
  //    server.on("/update", HTTP_POST, []() {
  //      server.sendHeader("Connection", "close");
  //      server.send(200, "text/plain", (Update.hasError()) ? "FAIL" : "OK");
  //      ESP.restart();
  //  code moved to update handle
  server.on("/inline", []() {
    server.send(200, "text/plain", "this works without need of authentication");
  server.onNotFound(handleNotFound);
  //here the list of headers to be recorded
  const char * headerkeys[] = {"User-Agent", "Cookie"} ;
  size_t headerkeyssize = sizeof(headerkeys) / sizeof(char*);
  //ask server to track these headers
  server.collectHeaders(headerkeys, headerkeyssize);
  server.begin();
  Serial.println("HTTP server started");
void loop(void) {
  server.handleClient();
