I'd like to use the WiFiManager library to bring up the initial config file and add my static IPs as shown here but want to do it on demand just as shown in this other example:
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
//needed for library
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#define TRIGGER_PIN 4
Serial.println("\n Starting");
pinMode(TRIGGER_PIN, INPUT);
// is configuration portal requested?
if ( digitalRead(TRIGGER_PIN) == LOW ) {
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//reset settings - for testing
//wifiManager.resetSettings();
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep
//in seconds
//wifiManager.setTimeout(120);
//it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
//WiFi.mode(WIFI_STA);
if (!wifiManager.startConfigPortal("OnDemandAP")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
I just don't know which line to modify.
Any help is appreciated.
